Engine cradle
Gripped
Engine cradle
Post by Gripped » Tue Jun 05, 2012 11:36 am
The cradle holding the engine has a big 3" diameter metal tube, welded to brackets in the bay under the front seats. The bracket and connection is getting quite rusty on mine. Is this common and is it problem?
Mickymouse
Re: Engine cradle
Post by Mickymouse » Tue Jun 05, 2012 12:10 pm
Mine was a bit rusty on the nearside,I cleaned it off with a wire brush and treated with Kurust and then painted with a black gloss metal paint,it still looks like new two years later!
White 1996 P.reg SGL3 2.5D AFT Side Conversion
321Away
Re: Engine cradle
Post by 321Away » Tue Jun 05, 2012 12:30 pm
it seems to be a problem, and only much on the passenger side for some reason? maybe cos the turbo gets hot?
Julian
Simon Jones
Re: Engine cradle
Post by Simon Jones » Tue Jun 05, 2012 12:39 pm
If you feel the need to change it, I have a spare one available.
Gripped
Re: Engine cradle
Post by Gripped » Tue Jun 05, 2012 8:21 pm
Yep, only on the pass. side.
I'll give it a wire brush and maybe under seal it.
Gripped
Re: Engine cradle
Post by Gripped » Tue Jun 05, 2012 9:26 pm
All done. Rust removed, which was fairly superficial. Kurust applied, and tomorrow I'll under seal the lot.
Thanks !
