On to the Headlamps tomorrow
I will try and take some tomorrow.stefan442 wrote:please send pics
The gauge is just reading over half.... seems stuck there. Need to get this sorted before I drive to the south of France next week!
This normally works fine but I think Stefan has poor resistance in the connections between the sender module ( think its just a variable resistor) and the top mounting plate, I have only seen this once but just fitted an aditional wire and it worked fine. The pipe work had a few small bits of corrosion on it so I felt this was causing high resistance and a false empty reading.daveblueozzie wrote:There are a few ways to re-earth the tank and sender, one from the lip of the tank to the chassis, the other from the wires on top of the tank to the screws surrounding the sender (the one i have done on about three bongo's )
http://www.igmaynard.co.uk/bongo/forum/ ... uel+sender
winchman wrote:Yes
Just take your time and dont let it get too hot
If you judge the size right you will just drill the head off allowing the sender to come out.
If you dont want to drill it, try soaking for a few days in WD 40 etc, give it a few taps with a hammer and a good small pair of mole grips should shift it, or snap it off, if you were local I would just come and do it
