So first problems encountered with the relatively new purchase!
I changed the rocker cover gasket this eve and noticed the black depsoits around the front of the block so delved in closer.  As I half expected the No:1 Stud has failed.  The thread is still visible, just the nut and final bit of threat has broken flush to the manifold.  So my question is, have I been sort of lucky? I'm assuming I can just whip off the manifold, nip a couple of nuts up on it and remove/replace??
After that I inserted a couple of Allan's EGR blanking plates, unfortunately some ham fisted berk has overtightened the bolt closest to the drivers door and knackered the thread, am I ok to use a larger bolt with a little cutting fluid? The ally looks pretty soft and chuncky in that area.
Thanks in advance,
Matt
						Manifold Stud No:1 & EGR to Inlet manifold fixing
- maxheadroom
Re: Manifold Stud No:1 & EGR to Inlet manifold fixing
Welcome and I would say Yes & Yes
this may help.
http://www.igmaynard.co.uk/bongo/forum/ ... ifold+stud.
thats the long answer to max's yes
ive seen a few with that particular bolt stripped out, mine included. imperial oversized coarse threaded bolt fixed mine
Top stuff, I guessed it would be ok but good to seek a more experienced yes!
Thanks,
Matt
						Thanks,
Matt
