Am I being paranoid!?(Reading only problems with other bongo's on here makes it worse as well!)
When I start my mongo all the dash lights eliminate and go off pretty much together apart from the oil light which stays lit for approx 1.5-2 seconds longer! Is this normal or might it mean I have a slow tappit,blocked strainer or some other issue?or have I got bongo anxiety!?
Obviosly I've checked the oil level and it's spot on
Oil light
Re: Oil light
The oil light on mine is normally the last one to go out... So long as it don't come back on again while the engine runs....!
Re: Oil light
there is an oil pressure switch and an oil level switch, may be worth changing the filter to a good quality branded one,or check you are on the correct grade of oil.
Re: Oil light
The higher the mileage gets on an engine,normally the more mail-bearing wear takes place,this can determine the oil light duration.There are other factors as well,oil pump/filter/by-pass etc etc.
It is always advisable to fit an oil filter with the non return valve/disk/dump vale fitted.
Cheers.
Cheers.
sunnyjim82
Re: Oil light
Ok thanks guys I'll have a look into those things
Re: Oil light
Mines the same, once its been stood takes ages to go out, changed oil etc and still the same
