Running a fridge off the leisure - how long will it last?
winchman
Re: Running a fridge off the leisure - how long will it last
Post by winchman » Fri May 04, 2012 9:56 am
[quote="scanner
Not overall they don't because the heating element is on all the time the motor of a compressor fridge usually only runs for less than 10% of the time (dependent on ambient temperature) and compressor fridges are much more efficient than absorbtion ones as well.[/quote]
Sorry forgot about the compressor going on and off, I wonder if the 85w rating is an average, or just whilst its running?
The problem I have with compressor fridges in campers is the noise, but thats just personal , oh and the cost
scanner
Post by scanner » Fri May 04, 2012 10:11 am
winchman wrote:[quote="scanner
The problem I have with compressor fridges in campers is the noise, but thats just personal , oh and the cost[/quote]
It should be the rating of the motor so only when running - they have no way of knowing how hot/cold it will be so how can they tell how long it will be running for to work out an average.
They aren't all noisy we had one in the Toyota we borrowed in NZ and you could hardly hear it running.
mikexgough
Post by mikexgough » Sat May 05, 2012 7:19 pm
CF-18 Waeco... 4 days in high summer at 20c plus on 110ah inc TV/Satellite/Lights ........
as for noise...... errr not as you would notice...
The noise myth has been banded about for many years in the Caravan circles.... it really is not an issue....even if it was...... a compressor fridge beats ant other hands down every time...... why do VW et al fit them as standard....
