Wheels not straight?
Dr Fingers
Post by Dr Fingers » Thu May 03, 2012 5:53 pm
Just noticed..when parked in 'straight ahead' position, looking from front, OS wheel is dead straight, but NS is pointing into the kerb at at least a 10degree angle. Doesn't look right at all, but van handles fine, doesn't drift or pull to one side..
Is this normal for a Bongo? If not, any suggestions? (2.5 TD).
Derek
Re: Wheels not straight?
Post by francophile1947 » Thu May 03, 2012 7:17 pm
10 degree toe out is not normal, but I suspect it's a bit of an optical illusion - try it on the flat.
That degree of misalignment would cause heavy tyre wear.
scanner
Post by scanner » Thu May 03, 2012 7:49 pm
francophile1947 wrote:10 degree toe out is not normal, but I suspect it's a bit of an optical illusion - try it on the flat.
Yes should be a little bit of toe-in not toe-out (no camel toe either :shock: )
