Oil
pollyden
Oil
Post by pollyden » Tue May 01, 2012 10:28 am
Yes, i know it will have been done to death & i know its not on the list of recommended lubricants, but is 5w30 fully synthetic oil ok to use in the Bongo powerhouse? :)
lazyb5
Re: Oil
Post by lazyb5 » Tue May 01, 2012 10:35 am
I found it a little thin when warm as mine used quite a bit when pulling a caravan. I have now moved to 5w-40 synthetic and the old girl doesn't use anywhere near as much. I think the original spec was something like 10w- 40 but I like mine a bit thinner on start up. I'm sure someone with more knowledge will be along to give a better explanation shortly :D
pollyden
Re: Oil
Post by pollyden » Tue May 01, 2012 10:40 am
Its ok. I just happen to have a couple of gallons & i cant use it in the motorbike, so i'll just use keep it for the car. . . :D
Re: Oil
Post by Northern Bongolow » Tue May 01, 2012 2:27 pm
dont use bike oil, its the same grade but different stuff.
pollyden
Re: Oil
Post by pollyden » Tue May 01, 2012 2:31 pm
Northern Bongolow wrote:. . .dont use bike oil. . .
I know. . . thats why i said, i cant use it in the bike . . . :mrgreen:
Re: Oil
Post by Northern Bongolow » Tue May 01, 2012 2:39 pm
oh, i thought you meant you had some bike oil left over, but had changed the bike. :oops: sorry.
pollyden
Re: Oil
Post by pollyden » Tue May 01, 2012 2:52 pm
Ha ha. . . no, i work at a Vauxhall main dealer & Vauxhalls pretty exclusively use 5w30 fully synth oil, so its easy for me to "obtain" this grade.
Cant use it in the bike as it makes the wet clutch slip.
Would've been good to use put it in the Bongo as i had a surplus, but as its not recommended, i'll just get some 10w40 semi-synth & use that & use the 5w30 fully synth in my car. :)
Re: Oil
Post by francophile1947 » Tue May 01, 2012 3:03 pm
I thought 5W/30 was the recommended grade for a Bongo :? - sure I've read it many times on here.
Re: Oil
Post by g8dhe » Tue May 01, 2012 3:58 pm
I hope so its what I've been using for 4 years!
pollyden
Re: Oil
Post by pollyden » Tue May 01, 2012 4:06 pm
Ok. . . will chuck the 5w30 fully synth in the old Bongo then ! :D
Mind you, mine is a 2.5 diesel, not a V6 petrol. . .
lazyb5
Re: Oil
Post by lazyb5 » Tue May 01, 2012 4:36 pm
Just checked the book and 5w-30 is the correct grade :oops: but I guess with a few miles the tolerances on engine parts have widened so I have used 5w-40 for about a year now. Hope I haven't just jinxed myself :lol:
pollyden
Re: Oil
Post by pollyden » Tue May 01, 2012 4:47 pm
Well, my old bus had a reconditioned engine fitted 27000 miles ago, so i guess the wear wont have set in yet. . . :)
helen&tony
Re: Oil
Post by helen&tony » Wed May 02, 2012 3:29 am
The correct oil for a diesel has "For Turbo Diesel" or similar written on it....oil for a petrol car just won't do....saving a few quid for the sake of ruining thousands isn't mathematically correct...
10/ 40 multigrade is an oil that starts at a higher viscosity than 5/30, and warms to the viscosity of a 40 grade when the 40 grade is hot...It will offer a better lubrication than 30 grade, however, in winter, a 5/40 will help with initial starting and lubrication, or even 5/30 if you are doing only short hops...
As stated many times on here, oils are better than when the Bongo was designed...take advantage of the better quality, and love your engine 8)
