Fuel cap problem
Re: Fuel cap problem
Post by g8dhe » Mon Apr 30, 2012 4:10 pm
These diagrams are better to see where the breather/vent pipes terminate, below the cap;
Petrol
http://lushprojects.com/bongopartsmk2/c ... o=.html#19
Diesel
wonkanoby
Post by wonkanoby » Mon Apr 30, 2012 4:30 pm
and if the cap cannot breath then niether can that breather pipe unless it has a hole in it
brorabongo
Post by brorabongo » Mon Apr 30, 2012 7:01 pm
I noticed once that when filling the tank (with veg oil), once the level reaches up inside the filler neck, fuel comes out the breather pipe.
ボンゴの激怒 pictures
teenmal
Post by teenmal » Mon Apr 30, 2012 7:17 pm
brorabongo wrote:I noticed once that when filling the tank (with veg oil), once the level reaches up inside the filler neck, fuel comes out the breather pipe.
That's how it works Donald,the fuel will find a level in both pipes,just like visi gauge,or water level.It also lets you know that the vent is not blocked.
WATP.
brorabongo
Post by brorabongo » Mon Apr 30, 2012 10:14 pm
teenmal wrote:It also lets you know that the vent is not blocked.
Just what I thought.
teenmal wrote:WATP.
:D
ボンゴの激怒 pictures
Post by g8dhe » Mon Apr 30, 2012 10:23 pm
Doesn't tell you anything about the vent in the Cap however ! Just that the only path for air to get in to replace the used fuel is via the Cap vent of course which is where we came in about 20 messages ago!
Post by Northern Bongolow » Tue May 01, 2012 5:06 am
WATP.
nah.
the breather pipe back to the filler is the breather for filling the tank with fuel (fast fill). the tank breather is the working breather for when the cap is on and the engine is drawing fuel.
