Fuel cap problem
Mark Norton
Fuel cap problem
Post by Mark Norton » Sun Apr 29, 2012 4:17 pm
Bongo is running very well with no apparent problems as long as I do not tighten up the fuel cap!
If I screw the cap down then I will conk out when going up a hill or when accelerating hard. Releasing the cap lets out the vacuum that has built up behind it.
Been driving like this for 2-3 years now and it's not a problem, but is this normal?
wonkanoby
Re: Fuel cap problem
Post by wonkanoby » Sun Apr 29, 2012 4:22 pm
its common
clean it as its little breather hole is blocked
Hollis
Post by Hollis » Sun Apr 29, 2012 5:09 pm
Is that on a petrol or diesel?
Derek
Simon Jones
Post by Simon Jones » Sun Apr 29, 2012 6:00 pm
I believe Mark has a diesel :wink:. My observation from owning both types is that the diesel tends it run with a slight vacuum in the tank which is why it's important the breather system is in working order to avoid fuel starvation. In contrast, the V6 petrol runs with pressure in the tank which is why you get a noticeable rush of air coming out when the filler cap is removed. This appears to be normal operation.
brorabongo
Post by brorabongo » Sun Apr 29, 2012 6:38 pm
I had noticed the same myself, so I took the cap apart. Cleaned it but did not make a difference so have been using the cap without the spring/flap since. Running with it for over a year now with no problems.
http://www.igmaynard.co.uk/bongo/forum/ ... ap#p427070
btw I never have a full take of fuel so don't know if it would leak if so.
ボンゴの激怒 pictures
ELZE
Post by ELZE » Sun Apr 29, 2012 6:53 pm
Cut the hassle out of ya life man and buy a new one. I got a locking one from Ebay, works a treat!
A Bongo is for life, not just for Christmas
Post by Northern Bongolow » Sun Apr 29, 2012 8:02 pm
the tank itself has a breather system someone put up some lush project pics up on a thread a while ago.
the breathers are clipped to the chassis, if it ever stops raining have a rummage.
undersealing etc can block or restrict them.
the cap alone cannot cope so these are needed,
longhaul8
Post by longhaul8 » Sun Apr 29, 2012 8:33 pm
Think this maybe what Ady is thinking of
longhaul8
Post by longhaul8 » Sun Apr 29, 2012 8:36 pm
And this is the topic the pic was taken from so may just help.....i hope it does
http://www.igmaynard.co.uk/bongo/forum/ ... er#p534423
Post by Northern Bongolow » Sun Apr 29, 2012 11:00 pm
cheers mate, :lol: , honest im not lazy, just hate puters. :oops: :wink:
longhaul8
Post by longhaul8 » Mon Apr 30, 2012 11:09 am
do you a deal you stick with the oily bits and i will try and keep clean using the puter :lol: :lol: :lol:
teenmal
Post by teenmal » Mon Apr 30, 2012 12:09 pm
Northern Bongolow wrote:the tank itself has a breather system someone put up some lush project pics up on a thread a while ago.
On a Diesel vehicle the tank is vented by a breather pipe from the tank to the neck of the filler pipe,if you remove the cap you will see the aperture for the pipe,any venting lower that that would result in an expessive leak.
:shock:
Post by Northern Bongolow » Mon Apr 30, 2012 12:29 pm
so is the link above posted by my puter expert buddy for the petrol. :? :wink:
longhaul8
Post by longhaul8 » Mon Apr 30, 2012 12:45 pm
Ady made me do it [-X [-X [-X
teenmal
Post by teenmal » Mon Apr 30, 2012 12:46 pm
Northern Bongolow wrote:so is the link above posted by my puter expert buddy for the petrol. :? :wink:
Hi,it does not matter whether its Derv or Spirit (petrol) the breather will always vent higher that the tank,usualy the neck of the fill pipe.
If you look at a garage(petrol station) forecourt you will see the high vent stacks,you also get some that will be connected lower,this would mean that they are using Stage 2 Vapour Recovery.(Just a bit of useless information)
