after owning my bongo for 4 plus years - i rekon its time for a coolant change
not any coolant loss or signs of hot temperatures - in all 4 plus years
so you can feel my reluctance to change it
my bro in law mechanic - doesnt smug and laugh at the bleeding method because he states he cannot comment and doesnt want to fit a new head if it all goes wrong
his garage is a very modern hi tech fit with all sorts of gadgets
he hasnt done a bongo before but has done other vehicles with heater matrixs in the rear etc
but what they do is add a gismo that pressurises the system at up to 20 psi and then gets the coolant sucked in and out with any air
hes been with the same garage for 24 years and works on all sorts of posh upper market stuff so i cannot doubt his knowledge and he states the same when i shown him the bleeding method video
well all you bleeders out there - give me a heads up
or the 2nd alternative is- i start extracting the coolant in the chamber and only refill the chamber with a high mix once a week to a fortnight and get fresh stuff in that way
at least it freshens the inhibiters etc
i do have a noise in that area which may indicate - water pump - manifold gasket - belts
so may have to strip and empty coolant if its the pump
but going to check all this out one cold morning - and locate the noise - it does stop once warmish and only makes the sqeelly noise when damp and cold - hence belts - gasket
cheer guys
andy
