Aircon running without the engine
helen&tony
Re: Aircon running without the engine
Post by helen&tony » Mon Apr 16, 2012 12:34 pm
One of these might help:
http://www.the12voltshop.co.uk/Shop/the ... 7250-.html
or this:
http://www.jacksons-camping.co.uk/cool/ ... ioners.htm
This one:
http://www.amazon.com/12-Volt-Portable- ... B001448O9K
The above works by pulling hot air in and blowing it through ice blocks / chips...I think ice is often available in European supermarts these days...or you can get some in the camp shops
winchman
Post by winchman » Mon Apr 16, 2012 12:43 pm
winchman wrote:I will ask the one who sits next to me tomorrow
He said you are mad, just run the engine, it can be done but far too much work
dave_aber
Post by dave_aber » Mon Apr 16, 2012 1:01 pm
Ah well, the sage has spoken.
I reckon the best solution is to have a switch to swap the supply to the heating / aircon system over to the L/B as & when required. This would allow me to use the Bongo's own fans to create airflow as a 1st stage if it's a bit warm.
If I need more cooling, run the engine as suggested.
Thanks to all for your input - if we don't chuck these ideas about, we'll never know eh?
Image...Image
Velocette
Post by Velocette » Mon Apr 16, 2012 1:14 pm
dave_aber wrote:Ah, of course, they have a hot side as well as a cold side.
I might just run the engine! :roll:
Trouble with running the engine is that it radiates a lot of heat into the cabin and continues to for several hours afterwards. Useful in the winter, problem if you want cool especially if you have dogs. I find the roof up with some vents open and the hatch open or bed stowed in the roof itself plus the side door or tailgate open gives some degree of natural cooling and help gets rid of the engine heat.
Post by g8dhe » Mon Apr 16, 2012 2:20 pm
Dave, it might just be worth investigating how much effort is required to turn the compressor when the magnetic clutch is not operated. Looking at the diagram the 61-L11 would appear to rotate the compressor without the rest of the belts and engine when the clutch is not operated, that might give you a clue as to how much torque/power would be needed to turn just the compressor alone.
Paulinwales
Post by Paulinwales » Thu May 03, 2012 10:02 pm
Just to give a fresh perspective on all this...
prob much easier and more effective to douse the bongo in water and let evaportion cool the whole thing, would prob cool the whole unit better than any hi-tek solution and cheaper. African fridges can cool to 8'c in 40'c heat with this method
don't do this in a hosepipe area tho!!! :lol:
briwy
Post by briwy » Thu May 03, 2012 11:01 pm
Stay in a hotel :roll:
