engine misfiring and smoke
hi,
hope someone can give some advice please.
I have recently noticed that above 2000 rpm the engine seems to misfire and also get smoke from exhaust.
The engine starts fine when initially starting but after warmed up I have had a little trouble starting.
any advice greatly appreciated
thanks
thanks
Re: engine misfiring and smoke
You could try changing/cleaning air and fuel filters.Presuming you have a Diesel vehicle..
Cheers.
Cheers.
teenmal wrote:You could try changing/cleaning air and fuel filters.Presuming you have a Diesel vehicle..
Cheers.
It is a diesel which has just had a full service last week. There is a company in Newcastle 'Just Diesel' who will look at it and put it on a diagnostic for £50 but I want to try a few things first. I will be changing the glow plugs weekend then maybe new noxxles on injectors, if it still chuffs after that then i may have it diagnosed.
A Bongo is for life, not just for Christmas
Sounds goodELZE wrote:teenmal wrote:You could try changing/cleaning air and fuel filters.Presuming you have a Diesel vehicle..
Cheers.
Hmm...hi ELZE...I think your mistakingly responding to my question...but i am glad youve had a full serviceELZE wrote:teenmal wrote:You could try changing/cleaning air and fuel filters.Presuming you have a Diesel vehicle..
Cheers.
If it's just had a full service I would take it back to where it was serviced and ask them why it misfires and smokes. Did it do it before the service and if so, did you point this out to whoever serviced it?
Changing the glow plugs won't fix it, they are only used when the engine is cold and are not operating at 2000rpm
Two suggestions: clean the banjo filter on the injector pump and try loosening the fuel filler cap slightly for a while in case you've got a problem with the tank breather system.
what engine is it, this sounds like a petrol engine problem, but if it is a diesel, check out simons thoughts.papillon wrote:hi,
thanks
papillon wrote:Hmm...hi ELZE...I think your mistakingly responding to my question...but i am glad youve had a full serviceELZE wrote:teenmal wrote:You could try changing/cleaning air and fuel filters.Presuming you have a Diesel vehicle..
Cheers.
Yes I di Sorry,,, had one of those days yesterday with to many interuptions at work when I am bongoing on the forum. Please forgive the intrusion I am taking the pills! Honest!
Simon Jones wrote:Two suggestions: clean the banjo filter on the injector pump and try loosening the fuel filler cap slightly for a while in case you've got a problem with the tank breather system.
Thanks for advice.
Now...being complete novice....hmmm....where is the banjo filter ( and injector pump) ?
