starter motor problem ???
jfallon
Post by jfallon » Tue Mar 06, 2012 6:23 pm
have a 1995 n plate automatic 2.5td 2wd - have a problem with what i think is the starter motor, have had a friend look at it and he replaced the main earth lead, the fault is still there, u turn the key and nothing at all- not even clicking, after several attempts of turning the key she will catch and fire up but its happening more often than not. Other than starter motor problems what other things could this be as want to try and avoid spending on something thats not gonna cure it.. any ideas much appreciated.. thanks
wonkanoby
Re: starter motor problem ???
Post by wonkanoby » Tue Mar 06, 2012 6:31 pm
jfallon
Post by jfallon » Tue Mar 06, 2012 6:39 pm
thanks for that link .. could it be something else like inhibitor switch or ignition switch as well ???
wonkanoby
Post by wonkanoby » Tue Mar 06, 2012 6:45 pm
does it get power to the main feed
but i still bet its contacts
one wears away with spark errosion
it was a fag paper deep on mine from about 1/4 inch start
jfallon
Post by jfallon » Tue Mar 06, 2012 6:59 pm
dash lights all come up ok, just nothing (no clicking) when u turn the key.. someone did mention the inhibitor switch for the automatic gear box but cant see any mention of this on here so wondering if it even has one !!??
teenmal
Post by teenmal » Tue Mar 06, 2012 7:42 pm
jfallon wrote:dash lights all come up ok, just nothing (no clicking) when u turn the key.. someone did mention the inhibitor switch for the automatic gear box but cant see any mention of this on here so wondering if it even has one !!??
It has an inhibitor on the side of the box,this is to stop you starting the vehicle in any drive position.
You could try and wiggle your gear selector when you turn the ign key.
It does look like contact fault..You really need to check the solenoid for power when you turn the ign key
jfallon
Post by jfallon » Tue Mar 06, 2012 7:58 pm
Thanks for all that, i will order a contact set tonight
:D
teenmal
Post by teenmal » Tue Mar 06, 2012 8:05 pm
jfallon wrote:Thanks for all that, i will order a contact set tonight
:D
Make sure that you don't have the heavy duty starter that is fitted to winter pack models.The ebay contact set is not compatible with the heavy duty solenoid.
Good luck
