Lambda Sensor: Part Number Required
Post by Ian » Tue Mar 06, 2012 10:30 am
Does anyone know the part number for the V6 Lambda sensor? Or know which page I can find it on Lush Projects?
mikeWalsall
Re: Lambda Sensor: Part Number Required
Post by mikeWalsall » Tue Mar 06, 2012 11:31 am
Strange .. I looked and could not find it listed ..
Bongobits sell OEM @ £245.21 but only list ..there own .. part number ..
http://www.bongobits.com/Main.asp?PageN ... roduct=316
From what I know most use 'wide band' pattern part Lambda sensor @ £35 .. £45
rita
Post by rita » Tue Mar 06, 2012 11:51 am
Oxygen sensor part number is J50518861A.
Post by Ian » Tue Mar 06, 2012 11:58 am
Cheers Rita. It's for an insurance job, so they need a quote for genuine Mazda parts. It's an expensive job; someone had their cat converter and their lambda sensor nicked while it was parked at a garage awaiting a minor repair! :shock:
Allans
Post by Allans » Tue Mar 06, 2012 1:15 pm
Theft of catalytic converters is on the increase. It's due to the scrap value of the platinum, palladium and rhodium metals they contain. There's a bit of security advice on the link. http://www.theaa.com/motoring_advice/se ... theft.html
Post by g8dhe » Tue Mar 06, 2012 1:26 pm
Rhinoman
Post by Rhinoman » Fri Mar 09, 2012 11:27 pm
mikeWalsall wrote: From what I know most use 'wide band' pattern part Lambda sensor @ £35 .. £45
The Bongo has a Wideband sensor? that doesn't seem likely are you sure its not just a standard 4-wire sensor?
1995 Ford Freda, 2.5TD, auto, AFT, side conversion.
mikeWalsall
Post by mikeWalsall » Sat Mar 10, 2012 12:21 am
I believe the pattern parts are 2 wire fitments .. but appear to work OK ..
