been advised that i should treat the inners
it has a rear conversion in it just now so i will need to work out the removal of this first.
once this is off how are the panels held on ?
afraid i cant see much until conversion is out - i assume its more or less clips same as the door panels? and there is a screw cubby hole in the middle
then i assume it's just waxoil squirted down inside?
inner rear wheel arches
MountainGoat
Re: inner rear wheel arches
Depending on the type of conversion that you have it should be possible to inject waxoil via the gas bottle cupboard and via the rear light cluster once removed. The problem is that you are working a bit blind can't see well enough to see if there is any rust that needs treating before injecting the waxoil.
Tony
Tony
and however or when ever you do it dont forget to pull all the seat belts out to the full extent or you will get them covered in the waxoil while on the cassette
Now thats a useful tipNorthern Bongolow wrote:and however or when ever you do it dont forget to pull all the seat belts out to the full extent or you will get them covered in the waxoil while on the cassette![]()
And warm the Waxoyl up before you use it to make it thinner so that it will get into all the joints better .
i've got the first side of conversion out and removed all the bits so i can get nice easy access
will hopefully do at the weekend - hopoefully nice weather
good tip for the seat belt - obvious but wouldnt have thought about it till too late
