Our temperature gauge started moving about yesterday on a journey down the motorway. It didn't go up above it's usual level but started falling a bit, sitting at the lower point for a bit and then coming back up again to its usual level. It never fell to the bottom. It did this a number of times and then stopped.
Coolant level is fine. No noise from the coolant alarm.
Any ideas much appreciated.
Many thanks.
Temperature Gauge wavering - downwards at least.
- Tribal Elder
Re: Temperature Gauge wavering - downwards at least.
Have a look at temp sender in engine the terminal on ours was corroded and did the same. A new sender does not cost very much. Cant remember where we got it from must have been bongo bits or ava .
Will do. Can you tell me where to look in the engine bay.
Many thanks
Nick
Many thanks
Nick
Wow! I like that picture!
Many thanks
Nick
Many thanks
Nick
- helen&tony
Remember to bleed the system if you remove / add anything to the cooling system...airlocks / air pockets can occur after opening the coolant system, even with something as small as a sender
All sender units now available via the online Bongo Shop (top right of screen).
