Driver door lock
davelochs
Driver door lock
Post by davelochs » Tue Jan 31, 2012 11:14 am
Hi there,
I need to replace the driver door lock on my mazda bongo 1995 4WD 2.5D but haven't found any online, can anyone advise where i might be able to source one? Should i try breakers yards?
dave
jaylee
Re: Driver door lock
Post by jaylee » Tue Jan 31, 2012 11:16 am
What's the problem with it..?
Post by Ian » Tue Jan 31, 2012 11:23 am
davelochs wrote:I need to replace the driver door lock on my mazda bongo 1995 4WD 2.5D but haven't found any online, can anyone advise where i might be able to source one? Should i try breakers yards?
Brand new ones are available from the Bongo Shop (top right of screen, above), in the Exterior section.
jaylee
Post by jaylee » Tue Jan 31, 2012 11:25 am
Nice one Ian... I was just about to put this up.... http://www.igmaynard.co.uk/bongo/forum/ ... 67&t=52959
This may help too...? http://lushprojects.com/bongopartsmk2/c ... o=.html#16
davelochs
Post by davelochs » Tue Jan 31, 2012 1:12 pm
Hi Ian,
forgive my ignorance, just had a look in the shop, does that mean i would have two different keys...the current one which locks the driver's door and starts the bongo and a separate key to open the drivers door?
David
jaylee
Post by jaylee » Tue Jan 31, 2012 2:09 pm
Hi, David... I had a cunning thought...! :-k (Just in case it means you don't get a suited key & lock set?)
Why not (if possible?) take the original lock barrel off (maybe) the passenger door? That will still leave the one key to open the whole vehicle with the manual CL & the ignition..?!! :idea:
I'm guessing on the basis you have no alarm/remote CL & my own habit of opening the side slider or the rear tailgate as i don't ever remember i four years of camping with a Bongo needed to open the front passenger side on its own....?? :idea: :arrow:
Post by Ian » Tue Jan 31, 2012 2:23 pm
davelochs wrote:Hi Ian,
David
Yes, you will end up with 2 keys. One for the door, one for the ignition.
davelochs
Post by davelochs » Tue Jan 31, 2012 3:19 pm
Thanks Ian
That's maybe an option Jaylee, do you know what effect that would have if i were to fit an alarm?
David
jaylee
Post by jaylee » Tue Jan 31, 2012 5:17 pm
davelochs wrote:Thanks Ian
David
In theory, none what so ever... You could/would have to fit an after-market actuator in the drivers door to control the full existing Bongo manual CL on all the doors, but that part only connects to the pull rod inside the door... (Part 58-390) http://lushprojects.com/bongopartsmk2/c ... no=.html#6 Some alarms come with remote CL control too... When you disarm, it unlocks & visa versa...
I get the feeling the damaged lock was an attempted break in??
Simon Jones
Post by Simon Jones » Tue Jan 31, 2012 5:41 pm
Another, more expensive/difficult option to to replace all 4 door lock barrels & ignition barrel with set from a scrap van. I'm sure I saw a set on ebay recently. That way, they'll all use the same key. Lot of effort though.
Simon Jones
Post by Simon Jones » Wed Feb 01, 2012 12:17 am
davelochs
Post by davelochs » Wed Feb 01, 2012 12:35 pm
Thanks Simon, that is a lot of work though, think i'll just buy the one new one and have two keys
Jaylee, yes it was an attempted break in, could have been a lot worse
David
jaylee
Post by jaylee » Wed Feb 01, 2012 3:05 pm
davelochs wrote:Thanks Simon, that is a lot of work though, think i'll just buy the one new one and have two keys
David
Sorry to hear that David, there are some real scroats out there...!! :twisted:
It really is that simple though, to fit a remote central locking actuator with an alarm if your getting the door panel off anyway..?!!
