Something loose in gearbox - loud noise
Auntie-Freda
Post by Auntie-Freda » Thu Jan 19, 2012 7:22 pm
Wife got home from work, after parking realised there is now big noise coming from the gearbox. Like a very loud bicycle bell (or maybe a bicycle bell crossed with a cow bell).
Sounds like something is loose and banging around in there. Its there when in neutral and all the gears, might disappear when driving but only drove it 200 yards so difficult to tell – it drives fine including reverse. There is 120,000ish on the clock so the old girl is getting on a bit. Any ideas.
M 80NGO
Location: Usually in My own wibbly wobbly lill world ! Otherwise Huntingdon.
Re: Something loose in gearbox - loud noise
Post by M 80NGO » Thu Jan 19, 2012 7:26 pm
Is it defo in the gear box or is something rattling underneath the vehicle and your mistaking it for inside the gearbox, for ease i'd whip the front seats up and check for something loose causing the metalic rattle your describing, exhaust clamp loose exhaust hitting the underside of the vehicle or even rattling on the back axel, eliminate all other possabilities first.
Keep us posted :wink:
danboy99
Post by danboy99 » Thu Jan 19, 2012 8:53 pm
I got that sort effect when a fan belt broke and the broken belt was flailing around and catching the alternator fins. It still drove ok because there are 2 belts...
Dan
Auntie-Freda
Post by Auntie-Freda » Thu Jan 19, 2012 8:54 pm
Found it! (after getting it up on ramps) It was the exhaust bracket that attaches to the back of the transfer box sheered off and bouncing off the exhaust pipe. Phew! =D>
Jimbob738
Location: Jaaaaacksdale! but a nottingham boy throught and through! you reds
Post by Jimbob738 » Thu Jan 19, 2012 8:56 pm
Big Phew! thats a hefty gearbox to be messing with glad your sorted.
Dabs
Post by Dabs » Thu Jan 19, 2012 9:13 pm
Good result!! =D>
Dabs
wormey
Post by wormey » Thu Jan 19, 2012 11:14 pm
Phew, :wink:
Daz and debs
M 80NGO
Post by M 80NGO » Fri Jan 20, 2012 8:03 pm
Auntie-Freda wrote:Found it! (after getting it up on ramps) It was the exhaust bracket that attaches to the back of the transfer box sheered off and bouncing off the exhaust pipe. Phew! =D>
No charge this time but if i ever have to answer another out of hours queerie for ya there will be a charge 8)
Glad you found it :wink:
