drivers window
jgk
drivers window
Post by jgk » Thu Nov 02, 2006 8:33 pm
hi all need some help again my drivers side window wont go down properly it starts off slow and stops do it again and its the same until it gets half way down and gose back to normal speed
press up and it gose up all the way no problems just on the way down
has any body had this problem before and how to sort thanks jgk
rwill19050
Slow window
Post by rwill19050 » Fri Nov 03, 2006 12:25 am
Sounds like a case of 'grease me please'
There are some runners in the door that guide the window, below them is a 'contraption' for want of betters words, that pushed the beast up and pulls it down, this being fed from the motor.
Being a window, water can ingress (ooh, posh) sorry, get in to the works.
This assumes the door has not been damaged (buckled or dented) in a manner that would imping (ooh posh) sorry, get in the way, of the window sliding up or down.
Seriously, I had a similar fault with a Rover, the problem was one of 'lack of lubrication'.
Sadly, the inner door panel never seemed to quite fit properly after my foray into it's innards.
Serves me right, should have left it to the professionals.
Don't delay though, a burned out motor can be expensive, and even worse, driving around with the window down in this cold weather...... :shock:
shakey
Post by shakey » Tue Nov 07, 2006 8:54 pm
JGK, just had a similiar problem on my Bongo, I cured it by lowering the window and spraying silicone spray into the upright guides in the window frame, window up/down, repeated spray. Sorted, might be worth a try before you do open door surgery. :D Shakey
David Edwards
Post by David Edwards » Wed Nov 08, 2006 2:16 pm
not only that but I know it sounds daft , clean the glass too its weird how dirt on the window can affect the operation.
jgk
Post by jgk » Wed Nov 08, 2006 8:04 pm
hi all greased it up its a little better shal try the silicone spray on it as well
where can i get the spray from and i`ll clean the glass too anything is worth a try thank everyone
white van man
Post by white van man » Thu Nov 09, 2006 1:05 am
remove door panel and check all mechanism bolts are tight as if loose the window can tip/jam
jgk
Post by jgk » Thu Nov 09, 2006 11:22 am
thanks for the links dave
shal check the bolt to be share thanks white van man
