Replacement front indicator bulb
My front indicator bulbs blown, any idea what size/type i need to buy?
Re: Replacement front indicator bulb
It's a n reg will check colour of bulb in the morning.
- Muzorewa
That should have orange lenses & clear bulbs, so P21W (Halfords 382)
Thank you.
Any plans to visit any motor racing this year?
- Muzorewa
Nothing definite yet but the Le Mans series at Donington Park in July must be a contender (so much better than Silverstone) and the Santa Pod European Finals
Do i have to remove the front/side light to change the indicator bulb or is it behind the screw cap with the headlight bulbs?
open the bonnet, at the rear edge of the indicator lamp is a plastic extension piece that screws to the top of the headlight next to it. remove the philips type screw, then pull the indicator lamp forwards, it sort of pops out, find the bulb mount and twist, the bulb is seen.
when replacing the indicator lamp carefully lign up the plastic guides that locate it to the panel, then push to the rear firmley.
