Vibrating steering wheel
mr brightside
Post by mr brightside » Tue Jan 03, 2012 4:52 pm
I'm a new Bongo owner. When I get up to about 60mph my steering wheel vibrates, but only when I'm accelerating (ie now when my foot is off the gas). Is this normal?
jaylee
Re: Vibrating steering wheel
Post by jaylee » Tue Jan 03, 2012 4:55 pm
Is it 4 wheel drive...?
Post by Muzorewa » Tue Jan 03, 2012 4:56 pm
60-65 is famous wheel-wobble territory for Bongos, normally balancing the wheels is all you need. Even if they've been balanced before, uneven tyre wear on the front causes this later :wink:
helen&tony
Post by helen&tony » Tue Jan 03, 2012 4:57 pm
That's the characteristic speed for the following faults:
Tracking
Wheel balance
Track rod ends
I had the same on mine...first 2 cured it!
westonwarrior
Post by westonwarrior » Tue Jan 03, 2012 4:59 pm
Could be tyres need changing or wheel balancing that is most likely the problem.
Post by francophile1947 » Tue Jan 03, 2012 7:35 pm
Balancing if you've got steel wheels. If you've got after-market alloys fitted, it may be that no spigot rings were fitted.
