stuck oil filter
mad as cheese bongo man
- Bongonaut
stuck oil filter
Hi All,
Happy New Year!
Can anyone recomend a tool for removing a stubben oil filter? i've just pumped out all the oil and now can't get the filter to budge, i've tried sticking a screw driver in it and it still won't turn. I can't put any new oil in it now as i've punctured the filter with the screw driver, so the oil will probably come staright out.
I see Amazon have a few tools that look like may do the job, does anyone know of any other ways to remove an oil filter?
Rob
Happy New Year!
Rob
M 80NGO
Re: stuck olil filter
You could make a filter wrench out of a good leather belt or even try wearing marigolds to get extra grip to turn it off by hand, halfords do a filter removal tool but you'll have to wait till tomorrow before you can get one.
http://www.halfords.com/webapp/wcs/stor ... yId_255216
- haydn callow
Marigolds as mentioned should do it....Halfords is open till 8pm here
There is a link to a review of various filter removers on the Wiki.
Makes interesting reading, as the best under test was well down the price list (£3.75).
(The Wiki also advises "Don't be tempted to punch a screwdriver through it. If it still won't come off and you have punched holes in it you are now immobile")
Owing to the fact that the filter is a bit restricted by the shield,I find this type easy to use.
http://www.ebay.co.uk/itm/DRIVE-1-2-OIL ... 519ba46635
- mikeWalsall
This type tends to be quite versatile .. and more expensive .. although I got mine from a car boot sale many years ago ..!!
http://www.ebay.co.uk/sch/i.html?_from= ... ilter+claw
get one of your wifes best tea towels or similar
twist it into a rope once round the filter, this will leave you with a twisted stump to use as a lever, you could push a small screwdriver through the twisted fabric to aid twisting and grip.
then get a large piece of steak for the black eye you recieve from the wife.
dont try to grip the torn filter with gloved hands or you will be attending a+e.
Re: stuck oil filter
I like these best http://www.google.co.uk/products/catalo ... I4BEPICMAU - really good in confined spaces.
Sticking a screwdriver through them used to be common practice - they seem to be made of thinner metal nowadays though
thats the one i use john, they give nice even pressure all the way around without crushing the filter if you use it on the outer edge.
- Bongonaut
Thanks All, you guys know yer stuff, i've ordered a Sealey Oil Filter Wrench off tinternet
We'll have to do without the bongo until i get it sorted
cheers
Rob
cheers
Rob
Just a thought Rob, as you didn't make it clear. You did punch the screwdriver in one side of the filter and out through the opposite side didn't you? If you went in one side only it is unlikely to turn the filter and will just make the hole bigger as you try turning the screwdriver, sorry if I am teaching granny to suck eggs.
Never run out of road, traction and ideas at the same time.
- mikexgough
Had one of These for 12 yrs now.... great in tight places and with 3/8 drive it also helps where access is restricted...works well even with wobble bars.... Used it on many different vehicles when the canister doesn't hand undo....
maviczap
Once you've got it off, when you come to fit the new one smear the seal with a bit of old oil or grease and only use your hands to tighten it as tight as you can do it.
Too many garage gorillas use a tool to tighten filters on, when its not necessary.
Which is why you can't get your filter off
- helen&tony
I've had most of the oil filter tools, and they have all proved unsuitable, straps, chains, and all sorts, until I bought one of these:
http://www.ebay.co.uk/itm/12-ADJUSTABLE ... _694wt_905
Never any trouble
Never any trouble
