Good brake pad recommendations ....
AeroNut
Post by AeroNut » Mon Dec 19, 2011 8:40 am
Hi all,
The little red brake warning light keeps poping up on me dashboard. I assume this means the pads are getting down and so time to look at changing them. :-k
Can any recommend what is a good make and possibly more importantly what to avoid...
...nice time of year to be out changing brake pads....... :-({|=
Thanks in advance
Regards
Terry
Re: Good brake pad recommendations ....
Post by Northern Bongolow » Mon Dec 19, 2011 10:45 am
dont fit the cheaper unbranded ones you will be fighting brake dust forever more.
ebc are good, they are on the net, gen mazda ones are also good but a little expensive.
mikeWalsall
Post by mikeWalsall » Mon Dec 19, 2011 10:56 am
Also check your brake fluid level ..
Alacrity
Post by Alacrity » Mon Dec 19, 2011 11:51 am
I bought mine from Mazda, I prefer not to cut costs on brakes. Pads (front) are £52.95 + vat retail (part no. ML0Z13328ZB) for my '98 2.5 tdi 4x4.
teenmal
Post by teenmal » Mon Dec 19, 2011 12:31 pm
Euro Car Parts are doing a 25% discount at the moment..code WINTER25.
Front and rear pads £41.80 with discount delivered.
AeroNut
Post by AeroNut » Mon Dec 19, 2011 2:01 pm
mikeWalsall wrote:Also check your brake fluid level ..
Good point...
didn't think is the warning light for the pads or the fluid? or both/either.....
Regards
Terry
mikeWalsall
Post by mikeWalsall » Mon Dec 19, 2011 2:09 pm
The (!) Brake light is for the Handbrake on .. low brake fluid and low vacuum (on diesels only)..
BUT .. I personally don't know if it also acts as a 'pad wear' indicator as well.
Post by Northern Bongolow » Mon Dec 19, 2011 2:51 pm
no it doesnt, well not on the earlier ones. just the fluid level like you rightly said earlier =D> =D> =D> =D>
edit
looked at this again and i suppose it does #-o #-o , as the pads wear the level drops so triggers the low fluid float in the res the pads may need replacing or at least checking.
teenmal
Post by teenmal » Mon Dec 19, 2011 4:13 pm
1= handbrake On warning light.
2= low brake fluid warning light
3=low vacuum warning light
4=dunno
AeroNut
Post by AeroNut » Mon Dec 19, 2011 5:03 pm
Out with the torch tonight then...........!
Thanks people
Regards
Terry
mikexgough
Post by mikexgough » Tue Dec 20, 2011 8:01 pm
Allied Nippon pads....... they are Factory O.E but boxed as A.N.... from Mazdabongoshop online.... low dust and top quality...
