fitting a leisure battery
littlehobo
Post by littlehobo » Tue Nov 29, 2011 9:44 pm
not sure what to do fit a second battery parrel circut
or split charge ystem is the splilt charge system easy to do also where do u put the battery all answers would be very greatfull thanks
:roll:
Re: fitting a leisure battery
Post by francophile1947 » Tue Nov 29, 2011 9:53 pm
Loads of info already on here.
Leisure battery is usually fitted under the bonnet on the passenger side.
Split charging systems are the easiest and lots of members use the Willinton (note spelling) kit, available from Ebay. If none are listed, contact the seller and he will list one 8)
nigelgibson
Post by nigelgibson » Tue Nov 29, 2011 9:54 pm
if you want a leisure battery you want a split charge system. Absolutely best is in link below. the tray will fit under bonnet right hand side but all instructions will be included.
http://www.ebay.co.uk/itm/MAZDA-BONGO-L ... 336df0c4c4
ps many of us [ me included ] have gone for cheaper options and regretted it !!!! :oops:
if you dont need tray see below
http://www.ebay.co.uk/itm/MAZDA-BONGO-1 ... 336ed55602
dandemann8
Post by dandemann8 » Tue Nov 29, 2011 10:02 pm
nigelgibson wrote:if you want a leisure battery you want a split charge system. Absolutely best is in link below. the tray will fit under bonnet right hand side but all instructions will be included.
Mention your a Bongo Fury member and you might get a discount :wink:
Bongo no more........... ;-(
nicstrike
Post by nicstrike » Tue Nov 29, 2011 10:14 pm
willinton....it's the way to go. you wont regret it. so , so easy! ( no connection other than being another very satisfied customer!)
spud350
Post by spud350 » Tue Nov 29, 2011 11:13 pm
Out of interest if you don't fit sockets in the van does the lb power anything else?
westonwarrior
Post by westonwarrior » Tue Nov 29, 2011 11:15 pm
the lb can power the lights (inside) lighter sockets, radio, blinds and any thing else you want it too its just in the wiring
Post by g8dhe » Tue Nov 29, 2011 11:21 pm
spud350 wrote:Out of interest if you don't fit sockets in the van does the lb power anything else?
The Willinton kit comes ready made with a wiring loom to plug into the existing fuse block to pick up all the likely circuits, one of the reasons that the kit is so well thought of!
Nogob
Post by Nogob » Wed Nov 30, 2011 7:26 am
Just posting another shout for the Willinton kit.
The design and instructions make it easy to fit - I'm the type of person who can just about change a plug as long as it's got the little instruction card with it!
Because it's purpose built, everything just fits, all the wires are the right length - it just works.
dave_aber
Post by dave_aber » Wed Nov 30, 2011 10:07 am
It's a quality piece of kit, well designed, packaged and most importantly, well supported.
If you have a fault, Martin will sort it out.
It is expensive, but realistic once you see the quality. The cost is long forgotten when I's been working for years without incident!
Click the pic for the full album.
Image...Image
Velocette
Post by Velocette » Wed Nov 30, 2011 11:56 am
I have just bought the above outfit from a Forum member who kindly fitted it and it is an excellent product and is very well made and thought out.
nicstrike
Post by nicstrike » Wed Nov 30, 2011 8:37 pm
the quality of the kit is superb. the only thing i changed was to slip a length of black pipe over each of the threaded bar part of the clamp assembly , purely for cosmetic reasons though! as has been said before , it's very reassuring knowing that you have the back up if ever you do have a problem. all in i would say its a very reasonably priced product.
philpdr
Post by philpdr » Fri Dec 02, 2011 12:22 am
Totally agree with nic above and Martin was happy for the kit to be picked up and cash paid to avoid the postage costs and paypal fees.
spud350
Post by spud350 » Fri Dec 02, 2011 9:28 am
They sound good but I'm not sure I'd get £200 worth of use out of it. I like the sound of using the internal lights at night though without worrying about starting the next day.
steveyd
Post by steveyd » Fri Dec 02, 2011 12:21 pm
HI,
I too was dubious of the cost and how much use I could justify it - but I have to say it gives great peace of mind when you're wild camping and you have the lights, radio and kids dvd thing going while you're cooking them their tea to know you can always start ok! Very usefull and very good quality.
I also have nothing but praise for Martins kits - the load sensing bit of the relay failed on mine whilst I was in Scotland - I managed to bypass with a manual switch, but Martin was prepared to pop a new relay in the post - in the end he sent it to my home and all's working well now. Still have to send the old relay back so he can work out what went wrong (I'm not as good as returning things as Martin is!).
cheers,
Steve
