We had out first overheating event last night. Saw the temperature dial was way up at defcon 5 so pulled over. Got noise as I pulled in which turned out to be bubbling coming from the header tank obviously not ideal, but I'm hoping that as it was boiling it can't have been bone dry so it could be worse
Having spent the morning doing research on bongo's I learnt all about how they need bled, and I released it may have been a mistake to drive it home as obviously this hadn't been done. I looked under the seat and for my life I can find neither the bleed hose, nor a hole where it should have been. The only evidence I found that it was ever there was that I had a little plastic clip on the far left of under the passenger seat, where the hose might probably should have been clipped. Could it have been removed, and the hole capped? Do some Bongo's not have these hoses? FYI - ours is a 1995 2.5lt diesel Ford Freda. Here's a picture of where I'd expect to find the hose based on previous forum info:-
http://www.flickr.com/photos/robdendy/6 ... /lightbox/
(sorry the image pasting function was telling me it couldn't ascertain image size - no clue as to why)
Can anyone identify where the hose ought to be? Cos I'm really not sure and I want to have something to tell the garage when I try to insist that they bleed it.
As it stands, my research so far suggests that my plan should be to get it to the garage, find and replace the leak, suggest we replace the thermostat, get them to pressure test the system and the radiator cap, and then make sure they bleed the system and use 50/50 water to antifreeze. Whilst there on it I'll probably get them to fit a low coolant alarm too. That's all assuming there's no bigger problems
Any comments anyone has would be very much appreciated.
Thanks.
Rob.
