I have noticed that the fluid level in the coolant tank is going down about 10mm a week I have checked all over , with no obvious signs of leaks
any ideas??
Steve
how many weeks? just one, or several.thepickles wrote:Hi all,
any ideas??
Steve
I have to tell you , borntobag, that this join is quite capable of leaking when hot!borntobag wrote:I had a coolant loss that was very illusive last year, the crimped seam where the plastic and metal components join at the top of the radiator was the culprit.
My theory is that when she is running at normal temp all is fine as the heat expands the joint in the radiator and keeps its integrity but when she cools the components contract and the pressure in the system is relieved through this weak spot. Then when she is parked up either all day or over night the little amount of fluid that has escaped evaporates leaving no signs of a leak apart from a drop in the tank.
helen&tony wrote:Hi Frank...
There are lots of epoxy putties on the market...if it is in a cardboard box containing 2 hard-ish round rods of material, then it's "milliput"...probably one of the best...two types...and the more rapid variety can even repair a split pipe under water...
Devcon do another one...and Devcon products are stupendous...
You'll find Milliput in model shops, and Devcon in the better class Hardware stores!
