Moderator: Ian
Echo.....westonwarrior wrote:thats good that is
what lights did you use?
Don't let the Ebay seller know they fit Bongos or the price will treble.redalan1971 wrote:http://www.ebay.co.uk/itm/ASTRA-F-MK3-9 ... 335cabe7a2
Very good quality comes complete with a wiring loom to connect them up complete with 3 relays and fuses inline all as part of the loom.
i fitted them by using the old lights sides and screwing them to the new ones then i filled the gaps in with chemical metal. that way the bracket was there for the side lights and the grills.
my old lights were really shot and lenses crazed so i didn't mind cutting them up as they were useless.
The grill was with the van when i got it and i assume is part of the mazdaspeed bodykit.
So far as I know flattening the dip beam is all that is required for LHD, I'm sure I read somewhere that most LHD lights just dip up and down.briwy wrote:Excellent.
The RHD/LHD lever could solve a lot of problems. Do you know if it actually alters the beam pattern or does it just flatten the dip beam for use abroad. My Octavia has a similar feature but all it does is flatten the dip beam.
If it does alter the beam pattern it would be the answer for peeps on here trying to get Bongos registered abroad.
scanner wrote:So far as I know flattening the dip beam is all that is required for LHD, I'm sure I read somewhere that most LHD lights just dip up and down.briwy wrote:Excellent.
