Mis-firing V6
haydn callow
Re: Mis-firing V6
Post by haydn callow » Mon Nov 07, 2011 11:08 pm
I had the problem when I first had the LPG.
Rota arm half fixed it and then a set of the correct plugs made it perfect.....Probably not the plug leads.
Plugs fitted are Bosch Super Plus YTTRUIM +8 FR 7 DC+
http://www.coolantalarm.co.uk
Also BMW Clocks
Bogmonster40
Re: Mis-firing V6
Post by Bogmonster40 » Wed Nov 09, 2011 10:01 pm
Do you mind if I ask where you bought these ?? I did find these leads online, not sure if they are the right ones for my Bongo ???
http://www.ebay.co.uk/itm/MAGNECOR-IGNI ... 5d3106c83e
Perhaps I am buying completely the wrong ones ?
V6 2.5i Tintop Aero Petrol/LPG
haydn callow
Re: Mis-firing V6
Post by haydn callow » Wed Nov 09, 2011 10:42 pm
I tried aftermarket leads.....no good at all....put the old ones back.....It was nothing to do with the leads.....
Also BMW Clocks
wishmaster
Re: Mis-firing V6
Post by wishmaster » Thu Nov 10, 2011 12:49 pm
If it were me i'd get them from the Mazda dealership in Cardiff. Victoria Park Mazda tel. no.02920 330211 :wink: or the club shop :)
Izzy
I have a plan and its as HOT as my pants
IZZY
http://s633.photobucket.com/albums/uu57/izzy2619/
Bogmonster40
Re: Mis-firing V6
Post by Bogmonster40 » Fri Nov 11, 2011 9:34 am
isnt the club shop closed at the mo ?? I have to get leads as mine are damaged.
so if I get a full set and a set of plugs that may sort my problem - still not sure which plugs to buy though or where to buy them.
I am right in thinking you cant just take the old ones out and put a new set in and hey presto turn the key and off you go - more like put them in turn the key and scratch the head when nothing happens !!! lol
haydn callow
Re: Mis-firing V6
Post by haydn callow » Fri Nov 11, 2011 12:40 pm
10 min job to change them......do one at a time and you won't go wrong.....get the "proper" bongo leads....about £160 a set....my experience with aftermarket ones @ £70 was not good...
Also BMW Clocks
wishmaster
Re: Mis-firing V6
Post by wishmaster » Sat Nov 12, 2011 7:16 pm
I use bosch super 4's pt.no. fr78x in my V6 for the past 3 years and their great. £3.49 each on eBay :wink:
I highly recommend them and wouldn't use anything else :D
Izzy
IZZY
