Hi, sorry if this sounds like a silly question from a newbie to the forum & the wonderful world of Bongo's, but does anyone know how I should remove the original jap stereo (2 din) without damaging the dash & what connections I need to fit a 2 din aftermarket stereo/cd/dvd player? My newly acquired bongo is a 2002 Aero 2.5td 4wd.
Thanks,
Phil
Tips on removing stereo
Philipino
Re: Tips on removing stereo
http://www.igmaynard.co.uk/bongo/forum/ ... +connector
im not sure on removal
i guess its keys like a normal single one
If you have an aero type you'll need this type of adapter, http://www.ebay.co.uk/itm/CT20MZ02-Mazd ... 2a14a48e47
The stereo removal varies depending on the brand, you'll need a cubby box if the new stereo is a single DIN type, like this http://www.ebay.co.uk/itm/CT20MZ02-Mazd ... 2a14a48e47, or if its a double it should just slot in
Julian
Julian
The Japanese radio in ours was a simple job of popping off the outer surround, and undoing 4 screws - but different models will vary
Jezza
- westonwarrior
ours was the same just 4 screws after the trim we then used the cage to fit the new one
wishmaster
- Tribal Elder
Same process when we changed ourswestonwarrior wrote:ours was the same just 4 screws after the trim we then used the cage to fit the new one
