cambelt change
xxchefxx
cambelt change
Post by xxchefxx » Tue Nov 01, 2011 9:24 am
Hi all
i have had my cambelt changed this week by a local garage but it seems terribly rough on startup and when idle im sure its not normal and plan to go back to the garage today but what are your thoughts that could be wrong? i know very little about cars but dont want to seem that way when i go back this afternoon to complain.
thanks
wonkanoby
Re: cambelt change
Post by wonkanoby » Tue Nov 01, 2011 9:31 am
could be one notch out
sparkymik
Re: cambelt change
Post by sparkymik » Tue Nov 01, 2011 10:02 am
Wonkanoby is spot on there I did mine back in March using the faq sheet, the replacement belt has to be spun round once or twice with the aid of spanners once fitted to confirm alignment first time I was one belt tooth out had to take it off and refit because it was slack took me all day but what an improvement. It's very hard to get too they will not be keen to go back under and strip out all the covers etc, but if they ain't done it right they are duty bound, also don't drive it to hard or far as it is, hope this helps get the faq and take it back with you
The Bongo has gone. Long live The Bongo
Hymer Camp Swing 544/Fiat Ducato 2.3jtd
xxchefxx
Re: cambelt change
Post by xxchefxx » Tue Nov 01, 2011 10:20 am
could you post a link to the sheet i cant seem to find it please
rita
Re: cambelt change
Post by rita » Tue Nov 01, 2011 10:39 am
It would be worthwhile checking the hose that goes onto the spigot here...1320....../93-4104,and any other vaccum hoses/spigots.
http://lushprojects.com/bongopartsmk2/c ... no=.html#5
haydn callow
Re: cambelt change
Post by haydn callow » Tue Nov 01, 2011 12:31 pm
Tip for getting the belt on correct.
Start the engine with the old belt in situ.
Hold a sharp stanley knife at the centre of the belt and cut through.
Stop engine.
Remove the "front" half of the belt.
Slide the new belt on.
Cut and remove the rest of the old belt.
Push the new belt fully home.
http://www.coolantalarm.co.uk
Also BMW Clocks
