cheffy34 wrote:Hey guys as you all know i'm having an issue with my van at mo as in being a ummmmmmmmmmmmmmmmmm shall we say non strarter
I am hankering towards coil/igniter direction now after changing a few things, after Andy's post on my last topic i am in two minds now wether i do have a good strong spark albeit i do have a spark at the plugs.
My question is am i right in believing that if the ignitor was at fault then there would be no spark from the coil
What exactly does an igniter do
My other question is why will it run albeit terribly if i turn the dizzy forwards and boy does it smell rich, turn it back to where it should be it dies is this all to do with bad spark or am i barking up the wrong tree,
HELP PLEASE GUYS
Dar
Let's go back to basics.......the ignition coil is an induction coil in an ignition system which transforms the battery's 12 v to the thousands of volts needed to spark the spark plugs. It then connects to the Dizzy.....
In older points systems when the points close, it allows a current from the battery to build up in the primary winding of the ignition coil. Once the current has built up to its full level, the contact breaker opens. More modern electronic ignition systems operate on the same principle, but some rely on charging the capacitor to around 400 volts rather than charging the coil.
Even newer vehicle use on the plugs coil packs where some are even "wasted spark" but we wont go there.
So on answer to your "igniter" and having not seen a Bongo V6 ignition system then this I would assume to be the same function as points used to do on a cleaner and more reliable scale. 80/90's petrol cars tend to have a small ignition pack which connects into the dizzy to replace the points (manufacturer designed etc).
Non starting yet you have a spark..... any tracking across from your ignition parts?....like shorting out?....worth a check or any small cracks in the insulation materials
Moving the dizzy is changing the timing/fuel mixture either advancing or retarding (engine dependent)......hence rich mixes.... to weaker mixes
What I would do is as I usually do with older vehicles, set all your ign timing to static....get it running then set it dynamic with a light .......it's difficult to pin stuff down without the engine to hand.....
