Help!!
Help!!
I have lost my one and only key!! phoned local mazda dealer, AA, Locksmith etc no luck! can anyone advise please!?
- bongodonkey
- Tribal Elder
Re: Help!!
Try billybongo - aka William Convey
He is based in Kirkcaldy and maybe able to help. Do a search on here for him or google and you should get his details.
Oz, Sam & the girls | 2001 V6 AFT | LPG | 321Away F/S/C | A Bongo called OLIVE
Re: Help!!
Billybongo is at Campercraft Kirkcaldy.
Are you absolutely sure there is no way of finding your key? As OH thinks if you cannot find it you may have to have all your locks changed.
Re: Help!!
I agree, without an original or the key number there is nothing that anyone can do. The Bongo is a Grey Import so all the key records will be held in Japan. Not getting a second key made is not very bright, I have three keys for my Bongo.
Tony
Tony
Re: Help!!
any good auto electrician, or mechanic could get it going pretty quick.
is there an alarm or immobilizer fitted.
- missfixit70
Re: Help!!
Any Mazda dealer should be able to get you a key sorted from the VIN/chassis number, pretty sure I remember reading the key number is on the lock barrel, but any "proper" locksmith should really be able to sort you out - shouldn't be called a locksmith if they can't, they are just a "keycutter" if that's all they can do.
Re: Help!!
Very true. Also anyone over six from Croxteth will do it in seconds!missfixit70 wrote:Any Mazda dealer should be able to get you a key sorted from the VIN/chassis number, pretty sure I remember reading the key number is on the lock barrel, but any "proper" locksmith should really be able to sort you out - shouldn't be called a locksmith if they can't, they are just a "keycutter" if that's all they can do.
