Rust
Rust
We don't appear to have a dedicated Rust thread. Could this be it?
anyway, Bertie appears to be developing a few very small rust spots ( sort of about 2-5mm) which are just starting to bubble through the paintwork. I am a complete noob regards this so:
What do I do now. Oh and *please* keep the responses serious.
Re: Rust
Where abouts are the rust spots?
Are they the seemingly "typical" rear arch ones?
What is the underside like? Has Bertie been waxoyled and undersealed?
I have a few spots on the rear arches that are being done next week, seems to be a bit of a weak spot on Bongos.
Why?...........Because somebody might wave back.
Re: Rust
Im interested in this too - i've the bubbles on the arches and the odd one elsewhere on the body work.
Would like to tidy themup for winter but knowing me i'll make a pigs ear of it!
Advice in laymans terms would be greatfully accepted!
Re: Rust
If anyone would like to post pics i will do my best to give advice on bodywork/paintwork. I work as a trainer in vehicle estimating and painting so i should be able to give an insight into the correct way to rectify the problem, money allowing of course.
Re: Rust
stuc wrote:If anyone would like to post pics i will do my best to give advice on bodywork/paintwork. I work as a trainer in vehicle estimating and painting so i should be able to give an insight into the correct way to rectify the problem, money allowing of course.
Eyup Stuc ~some help would be appreciated on my Arch please.
Regards Ray & Christine
Re: Rust
Thank you mate~~it does look beyond repair don't itlazyb5 wrote:I`d sell it Ray it looks beyond help mate
Re: Rust
I would advise you do not drive this vehicle until it is fixed, it looks rather unsightly and will upset the airflow around the vehicle body, causing extra load on the engine, which will increase engine temperature and possible overheating.
Just kidding, it looks to me as if they have already been done at some point, so i would advise rubbing down, dig the filler out and refill and shape ready to prime and paint, without replacement rust will always come back through. Shouldnt be too expensive at a bodyshop. Check it has been sealed and waxoyled correctly, but i suspect the rust is between the seams.
Re: Rust
Thanks for reply Stuc ~it was waxoiled when i bought as a fresh import~~i've also done it from back to front including wheel arches,but not between the seams (from inside) so will have a look from inside when time allows~~would it be better to leave it through winter,then sort it out Springtime???stuc wrote:I would advise you do not drive this vehicle until it is fixed, it looks rather unsightly and will upset the airflow around the vehicle body, causing extra load on the engine, which will increase engine temperature and possible overheating.
PS glad you enjoyed your first meet this weekend.
Re: Rust
Me personally, would let the winter do its worst and tidy it up ready for next season. Even from inside you would not be able to get between the seams without cutting away the arches. We can only do our best to keep the tinworm at bay.
- Junior Bongonaut
Re: Rust
Hope this thread ain't closed yet! Rust! Firstly my trusty Bongo has the usual wheel arch rust as described earlier in this thread. Tried to repair it but it just came through again so must be coming from in between the twin "skins". So I drilled a hole inside the wheel arch and pumped in some hot wax oil. Hope this will help sort out the inside rust before I repair again.
Whilst under the rear axel I noticed that where the sills meet the wheel arch, i.e. at the bottom front part of the arch, there is a hole. No rust this time but a proper hole as if it had lost a grommet. Same on the other side. Is this usual or is a grommet missing. Strange as both sides have this and both offer an ideal access for salty water to get into the sills area. Does anyone know?
Re: Rust
Not sure where you mean, pics would be good and we will come up with an answer. Hopefully.
- Junior Bongonaut
Re: Rust
Thanks for that Stuc. I have attached a pic. This is the passenger side rear wheelhousing looking forwards - see the hole at the bottom of the inner wheelhousing? Should it be open or is a grommet missing? Same on other side. You can also see signs of wet - that is the waxoil I pumped in. BTW I mentioned in my previous post that I drilled holes in order to pump hot waxoil into the inner skins above the wheel. I forgot to mention that I also inserted 8mm grommets afterwards! You have no idea how difficult it is to find 8mm grommets - had to order the web.
http://www.tagureworld.com/BongoSillHole.JPG
Re: Rust
Hi, I am sure someone will correct me if wrong but, I dont think they should be there, mine didnt have them before i did the arches. That hole would go straight into the box section of the sill by the looks of it so i would put some grommets in if i was you. Would be good if anyone could check an original one.
