Hello.
My Bongo recently needed the radiator replacing however, I noticed yesterday (the work was only carried out a few days earlier) that the plastic filter/end section that runs from the air filter and sits across the top of the radiator, is missing. The garage can't find it so have suggested that I try and find one (as they know I use various Bongo dealers/parts specialists) and they'll buy the part. Can anyone confirm what this part is commonly known as?
Thanks in advance for any advice.
Jason
Help needed identifying name of required part
- haydn callow
Re: Help needed identifying name of required part
I just call that the air intake for the heating system...hell of a big bit to lose
Here you go....Jayster wrote:Hello.
Jason
Jayster
That's very kind of you, but sadly I can't make head nor tail of that diagram. My head just can't compute that sort of information.rita wrote:Here you go....Jayster wrote:Hello.
Jason
Is the part listed on the link below the part that I'm looking for?
http://www.ebay.co.uk/itm/MAZDA-BONGO-F ... 500wt_1054
Jayster wrote:That's very kind of you, but sadly I can't make head nor tail of that diagram. My head just can't compute that sort of information.rita wrote:Here you go....Jayster wrote:Hello.
Jason
Hi that part is the Intercooler intake..
Do you know if the part you require is on the Top of the radiator?if so its the cover 61-820 on the first drawing that you require.There are a few versions of this cover,check VIN number before ordering.
