waycar8 wrote:Well from what I could gather from my part disasemble is that they just hold the inner plastic housing for the main spindle that spins what has a magnet on the end closest to the "nuts", not sure they are for an earth as such.jaylee wrote:What i got is not really major a problem for me, as such...waycar8 wrote:Hope it cures your problem, might well be a cure to alot of alternator problems
or just a odd bongo abnormality
Maybe after a certain amount of time with the vibration they do just work themselves loose, don't recall seeing any thread lock on so maybe a design flaw? who knows only time will tell Ive made into a sticky just in case and hopefully anyone else may be able to add to the thread or blow the theory out the water
I was however, wondering if it would do any harm running an earth to chassis off one of the five bolts.? (A bit like the old fuel gauge fix..!)![]()
I was thinking of putting an extra nut on each thread to lock em in anyway?
Must have something to do with how the magnet sits near to the outer caseing imo causing static leccy?
http://lushprojects.com/bongopartsmk2/c ... no=.html#1
Some sort of alloy..?
