Oil leak update advise req
M 80NGO
Location: Usually in My own wibbly wobbly lill world ! Otherwise Huntingdon.
Post by M 80NGO » Sun Jul 31, 2011 10:48 pm
I thought my beloved bongo was losing oil from the crankshaft oilseal but after a very helpful phonecall to the very nice people at bellhill i can confirm that the oil is coming from somewhere highr up on the front drivers side of the engine but i'm not sure where exactly, yesterday i removed the undertray took the bongo and my car ramps to the local jetwash, once she was up on the ramps i cleaned the engine with a spray bottle filled with brake and clutch cleaner starting underneath and then under the seats. I left it parked last night outide my house without undertray and a clean sheet of cardboard underneath as per bellhills instructions and she's defo loosing about a desert spoon of oil while she's parked up but i just cant make out where its leaking from, i had it up on the ramp again tonight and can't see anywhere that its running down the engine the only oil drip i could see was on the gear selector cable where it passes under the corner of the engine.
I have checked all the inlet manifold bolts for tightness as per B/H instruction and i did get half a turn on the rocker cover bolts so i'll just have to continue the search.
Are there any places that the bongo is common for oil seepage ?
Thanx, Pete.
Re: Oil leak update advise req
Post by missfixit70 » Sun Jul 31, 2011 10:54 pm
Are you sure it's engine oil? Have you been having to top it up regularly? Could it be diesel or steering fluid? Is the drip/loss looking bigger because it's spreading out on the cardboard?- a little bit of oil can look like a lot when it spreads out.
Could it be gunk (from egr and/or crankcase breather feeding oil into the air inlet pipework) dripping from the air inlet manifold?
M 80NGO
Post by M 80NGO » Sun Jul 31, 2011 11:02 pm
Its defo black oil, not diesel as its to thick and i've already cured that leak, not steering fluid either as that level never moves.
Post by missfixit70 » Sun Jul 31, 2011 11:23 pm
But are you having to top up the engine oil regularly? A desert spoon overnight, therefore @ 2 a day, is gona add up to about half a litre every 4 weeks?
(desertspoon = 10ml x 2 x 7 = 140ml per week x 4 = 560ml every 4 weeks) Yeah - I'm THAT bored :lol:
M 80NGO
Post by M 80NGO » Mon Aug 01, 2011 9:11 pm
Yes i do top up 200ml every 2 to 3 weeks but since giving all the rocker cover bolts half a turn each the leak seems to be seriously reduced, just a couple of spots on the cardboard s,morning so i'll be monitoring it daily to see if i have stemmed the flow [-o<
Gripped
Post by Gripped » Sat Sep 17, 2011 8:59 pm
We've had a weep from the rocker cover.... (really it's a cam cover on a modern engine!) but seemed to be a bit worse recently. So after some helpful advice from this forum I nipped up the bolts. I used my trusty Halfords torque wrench and did each to 8 nm.... which is bicycle torque territory ! It was interesting that about half of the bolts needed a turn and moved a fair bit before the wrench clicked. Lets see what happens.
=D>
