Engine cut off thingy has stopped working?
paulo9992006
Post by paulo9992006 » Wed Oct 25, 2006 4:56 pm
Firstly sorry if anyone has emailed me and I have'nt replied but I have been away and my membership expired so I have re registered.Anyway as you can tell by my heading I am pretty clueless when it comes to engines.My vehicle used to run for about 40 seconds when I turned the ignition off which i understand it is supposed to do to protect the turbo.The engine has started to go off immediately when I turn the ignition off however.Is this right,have I switched it off accidentally or is it not working?Any advice would be greatly appreciated as I do not have an owners manual to check.If anyone knows where I could also get an owners manual that would also be appreciated. I thought i had better not drive it until I am sure so I am currently bongoless!!Thanks allot, Paulo
antique
engine stop
Post by antique » Wed Oct 25, 2006 5:04 pm
hi has the van got a turbo timer because that is the only reason the engine will run on if its got a turbo timer you can reset it ? if it hasent got one its probally the stop solenoid on pump
antique
engine cut off
Post by antique » Wed Oct 25, 2006 6:04 pm
hi sorry forgot to say yes all the time you can switch the engine on and off its safe to drive ?
Simon Jones
Post by Simon Jones » Wed Oct 25, 2006 6:07 pm
