which fuse
jaylee
Re: which fuse
Post by jaylee » Sat Sep 10, 2011 11:09 pm
Hold on... lets clear something up. Do you have this stuff live from a leisure battery?? If so? you may have an inverter hidden somewhere?? Perhaps behind the rear panel, near the lighter socket..? Just a guess!
Re: which fuse
Post by missfixit70 » Sat Sep 10, 2011 11:11 pm
See my link to Alifriendee's thread earlier :wink:
Re: which fuse
Or it could just be you've got a leisure battery on the way out?
jaylee
Re: which fuse
Post by jaylee » Sat Sep 10, 2011 11:26 pm
missfixit70 wrote:See my link to Alifriendee's thread earlier :wink:
:roll: #-o I normally loose interest after 3 pages... #-o :oops: By the way, fer crying out loud! Somebody lock DIY non invasive temperature gauge probe placement ideas... :lol: :lol: :lol: :lol: :wink:
Re: which fuse
Post by missfixit70 » Sat Sep 10, 2011 11:29 pm
You started it :wink: :lol:
jaylee
Re: which fuse
Post by jaylee » Sat Sep 10, 2011 11:36 pm
missfixit70 wrote:You started it :wink: :lol:
No invasion of Poland jokes please....! [-X
peanutcrusher
Re: which fuse
Post by peanutcrusher » Sun Sep 11, 2011 9:55 am
right what i think i'll try is to disconect the whole light fitting, does have a plug on it or will i need to cut the wiring?
the battery is brand new.
there are no invertors in the van so its not that.
it seems to flatton the battery in about a week with no use to the van.
Bongo now work later !!! :) :)
Re: which fuse
Post by missfixit70 » Sun Sep 11, 2011 12:02 pm
:wink:
missfixit70 wrote:It's only usually the middle flourescent type light that can cause the issue, only takes a few minutes to remove it.
Grip the sides of the plastic lens at the switch end firmly, squeeze & pull down to remove it, then you'll see 3 screws holding the fitment in place, undo those, then you can access the electrical connector behind, undo that, job done :D
peanutcrusher
Re: which fuse
Post by peanutcrusher » Sun Sep 11, 2011 7:40 pm
ok i have disconected the the light i'll see what happens.
