Wish me luck!
Cheers, I sprayed some ACF50 on them last Sunday so hopefully it will have done the trick. And on the air intake hose screws too!missfixit70 wrote:Easy peasyyou'll be fine, may be worth a squirt of penetrating oil on the bolts tonight ready for the morrow just in case, 1 or 2 have had trouble getting them off, but it's usually pretty easy.
Cheers, I've watched that a couple of times, it's very good. Hope I can get the battery disconnectedDabs wrote:Little video here from Ozric!!
May help!!
http://www.youtube.com/watch?v=5pnySma88gY
Dabs
It might also be possible to do it through the rear access panel, would give good access to the three main bolts, the electrical connections could be done form underneath if necessary, in fact the whole job probably could be done that way. Either way the air intake could stay in place. Not sure how much the bellypan would get in the way as mine got forgotten by the garage when I had the head jobwestonwarrior wrote:5 bolts hold the seat on, 2 at the frontof the slider, 2 rear and the seatbelt, removing the seat is a 2 min job and the hatch will go up plenty then.
Don't forget though there is an electric wire connected to the underside of the seat that needs disconnecting as you lift it out
