Drivers Window Switch
hershambongo
Post by hershambongo » Tue Aug 30, 2011 10:52 pm
My electric window switch has finaly given up ! after lots of taking apart and messing about with ! however just my luck its left the window down ! so Bongo is now sitting outside with just a bin bag to cover the window ! any ideas on how to close the window ? while I try and source a new switch for a reasonable price !
HB #-o
Re: Drivers Window Switch
Post by Bob » Tue Aug 30, 2011 11:11 pm
Possibly the wires broken where they run from the door into the wing, common problem.
Post by missfixit70 » Tue Aug 30, 2011 11:16 pm
If you take the black rocker part of the switch off the top, the slider underneath can usually be operated still. As Bob said, worth checking the wiring between door & frame too if that still doesn't work.
