White plug by the handbrake switch ?
tonnee
Post by tonnee » Thu Aug 18, 2011 11:09 am
Noticed last night I had a white plug not connected to anything by the handbrake switch under the centre console, then found a matching white plug tucked under the carpet, any idea what this is for before I connect it up ?
Tony
1995 Bongo Auto Free Top 4WD
http://www.justgiving.com/tony-sahara
jaylee
Re: White plug by the handbrake switch ?
Post by jaylee » Thu Aug 18, 2011 11:42 am
I think i know the one!!? (Sort of hanging round part 64-326.) http://lushprojects.com/bongopartsmk2/c ... mgno=.html
Do you have working speakers in the back? Though funny enough, from memory it's a two wire connector...?
The speaker Q is sort of relevant.... 8-[ read somewhere that a connector for the rear speakers was in this vicinity???
Don't quote me.. I would have thought a 4 wire connector? However, it may just be for the drivers side rear...?
haydn callow
Post by haydn callow » Thu Aug 18, 2011 11:42 am
Probably the seat belt warning light.
http://www.coolantalarm.co.uk
Also BMW Clocks
jaylee
Post by jaylee » Thu Aug 18, 2011 11:45 am
haydn callow wrote:Probably the seat belt warning light.
That's under the drivers seat...
tonnee
Post by tonnee » Thu Aug 18, 2011 11:46 am
its a two wire connection, speakers all work fine Jaylee, I'll check the seatbelt warning light shortly then connect it together see what it does ?
jaylee
Post by jaylee » Thu Aug 18, 2011 11:51 am
tonnee wrote:its a two wire connection, speakers all work fine Jaylee, I'll check the seatbelt warning light shortly then connect it together see what it does ?
Does the seat belt warning currently come on & go out when you strap in with the engine running..?
Scrap my last idea then... :oops: :oops:
Give me an hour & i can go out to mine & see what stops working when i disconnect...! :shock: 8-[ 8-[
tonnee
Post by tonnee » Thu Aug 18, 2011 11:55 am
hahah you know I have never even noticed a seat belt warning indicator :?
I'll connect it back up at lunchtime and see what lights up before you go unplugging yours then let you know
jaylee
Post by jaylee » Thu Aug 18, 2011 12:03 pm
Sorry Haydn...... :cry:
You were ruddy well right... =D> =D> =D> Seat belt warning! 8) :mrgreen:
jaylee
Post by jaylee » Thu Aug 18, 2011 12:12 pm
My adjustable lumber support & back massager stopped working too....! :arrow:
Post by missfixit70 » Thu Aug 18, 2011 6:14 pm
jaylee wrote:My adjustable lumber support & back massager stopped working too....! :arrow:
As did Ady's heated seat :wink: :lol:
jaylee
Post by jaylee » Thu Aug 18, 2011 11:18 pm
I thought Ady had one of those flashing wiper stalks fitted....?
Post by missfixit70 » Thu Aug 18, 2011 11:20 pm
Nah it's a wiping flasher stalk.
jaylee
Post by jaylee » Thu Aug 18, 2011 11:24 pm
#-o Of course...! I get them both confused... :?
