A sticky problem
Moderator: Ian
A sticky problem
Well I've removed my Friendee decals ( and what a faff THAT was) but can I get rid of the adhesive residue? No I can't. I've tried White Spirit and I've tried Auto Glym tar remover and I've tried staring at it malevolently, but it's still clingin' on.
Any suggestions?
Any suggestions?
'Enjoy every sandwich'
buntytw26
- westonwarrior
Re: A sticky problem
try wd40 but lots of old fashioned elbow grease
Desolvit Sticky Stuff Remover. You can get it in Poundshops and possibly Wilkinsons. I believe it is Citrus based.
eckerB
I used Cellulose Paint Thinner,worked a treat and removed all the glue!A good polish afterwards
and as good as ever.
I've got the same issue - got the decals off but not the adhesive (yet). Guess there's no escaping the fact that some time and elbow grease will be required whatever substance is used.
I was wondering about thinners, but was worried about damaginig the paint/lacquer?
Blimey, that stuff looks scary. And I don't think I could afford the protective suit and breathing apparatus.
Tried WD40 but no luck, so off to get some cellulose thinners now; if that doesn't work then I'll see if I can get some Desolvit.
Ahah! Methylated spirits seems to do the job but it's flippin' hard work. Still, you can always take a quick fortifying swig from the bottle when you start flagging
buntytw26
Some kind gent gave me a can for free!
The Polished Bliss chaps are not far from me and they do cracking jobs on yer motor.
If I could get photo bucket to work I'd add a couple of pics of a friends car.
Sorry, I digress.......
I don't think i would be using thinners!
M 80NGO
I used nail polish remover and elbow grease
Germarchip
I tried everything, but the guy at the spray shop told me to use Petrol. And it did work!!!! Still took alot of elbow grease
cabte
So many people i hear advising to use thinners ...
It does what it says on the tin,,It thins.
Iv been doing decals for years now and i have seen what it can do to your bodywork,
Maybe not straight away but belive me thinners can takes of layers of paint within seconds.
THINNERS IS A DEFO NO NO..
as advised by the paint shop petrol will do the job,
I use it many other signwriters use it,
I seem to have used everything so far - including thinners! I certainly haven't noticed any significant lifting of the paint, nor any paint transferred onto the cloth. I think my best results so far have come from Methylated Spirit, but by heck it's a long job - softening the adhesive isn't a problem, it's lifting it off rather than just smearing it around that's the problem. With hindsight, I wish I'd just learned to love the decals!
