Adjusting handbrake
briwy
Adjusting handbrake
Post by briwy » Mon Aug 08, 2011 7:00 pm
Fitted some new pads on the back yesterday and decided to clean out and adjust the handbrake while I'd got it up on axle stands and the wheels off.
Problem was turning the drum to get the hole to line up with adjuster. The van was in Neutral with both rear wheels off so I thought they would turn easily but no. Eventually managed to turn them enough, only needed a bit, using a bar on the wheel studs but surely there must be a better way
Why wont the wheels turn easily when both off the ground? Its a 4WD with an LSD on the back.
Had the same at front later when I had the wheels off just to check things.
Re: Adjusting handbrake
Post by Northern Bongolow » Mon Aug 08, 2011 7:19 pm
if you wish to turn 1 wheel you will have to lift 1 front,and 1 rear if its a 4wd(unless you turn the wheel really slowly,if you try to turn it fast it will lock up the t/converter as it should.
it is very unusuall to have a 4wd and limited slip,are you sure of this brian.
briwy
Post by briwy » Mon Aug 08, 2011 8:22 pm
Hi Ady.
Thanks for that. Thought it might be something to do with the LSD but not had the problem before on cars with LSDs
Well I'm going on the fact that its a 2001 year and I was under the impression that they all had LSDs after about 2000.
I'll get the VIN and put it into the Russian site and check.
Just had a quick crawl under and the diff has a yellow sticker saying LSD.
Post by Northern Bongolow » Tue Aug 09, 2011 4:33 am
its a first for me that one bri,4wdrive and a limited s/d.
jack both back wheels up and one front. turn the rear wheel, if the other rear wheel turns the same way its lsd,if it turns the opposite way its not lsd.
the front wheel up is just to allow the 4wd to drive through the transfer,if its down it will lock up the drive/transfer box and lock up the back wheels unless done really slowly with little effort/force.
look on the internet for testing the tranferbox,there are some good videos on there.
skater
Post by skater » Tue Aug 09, 2011 8:40 am
If you're turning a rear wheel by hand you may not get it fast enough to make the LSD work
so the opposite wheel may still turn the opposite way. I'd trust the sticker I think.
Try doing some doughnuts in your local supermarket carpark and see if you get loads of inside wheel spin :-" [-X
" it's not rocket surgery! "
briwy
Post by briwy » Tue Aug 09, 2011 11:24 am
Russian site confirms its 4wd with LSD
Post by Northern Bongolow » Tue Aug 09, 2011 11:30 am
:) do you want to sell it brian--looks like its going to snow soon. :) .just needs a manual box and that would pretty much be a perfect setup. :wink: .
briwy
Post by briwy » Tue Aug 09, 2011 12:08 pm
A manual gearbox with flywheel clutch etc just gone on ebay for £62.
Was tempted to have a play.
Post by Muzorewa » Tue Aug 09, 2011 7:43 pm
Ours is 4WD with LSD rear axle too. Never got stuck yet :wink:
Post by Northern Bongolow » Tue Aug 09, 2011 11:15 pm
briwy wrote:A manual gearbox with flywheel clutch etc just gone on ebay for £62.
i was watching that too.it didnt sell the 1st time round. someone got a bagain.
hes a good seller that chap.
didnt know that paul. :shock: . thats why you keep going over woodhead, for a play. better watch out though brian may be coming the other way, :lol: :lol: :wink:
briwy
Post by briwy » Thu Aug 11, 2011 10:05 pm
Be OK. Muz'll be stocked up with noodles and beer.
