Anybody recognise this?
nybongo
Post by nybongo » Mon Aug 01, 2011 7:49 pm
My wife is in Kent (Sutton) tonight, catching a ferry in the morning. She found this under the bonnet not attached to anything. Does anybody know what it is and whether its important?
from somewhere between the starter battery and air box (central plastic box?)
cheers,
NYB
Simon Jones
Re: Anybody recognise this?
Post by Simon Jones » Mon Aug 01, 2011 7:51 pm
It sits in front of the battery and seems to act as a baffle for the air intake. Sorry, don't have a picture to hand.
nybongo
Post by nybongo » Mon Aug 01, 2011 7:57 pm
Thanks for that. Any idea how its supposed to be attached or whether its required?
She reckons it goes here, which would tie with what you say.
Post by g8dhe » Mon Aug 01, 2011 7:57 pm
Yup here is a photo;
I think it helps keep water from coming thru the front grill and splashing across the battery and its terminals. Not sure how its fixed, but those two holes are suggestive!
Post by missfixit70 » Mon Aug 01, 2011 7:58 pm
The 2 holes attach to the heater air intake ducting via plastic scrivets, I usually poke the battery end between the battery & the clamp upright.
maxheadroom
Post by maxheadroom » Mon Aug 01, 2011 7:59 pm
Simon Jones wrote:It sits in front of the battery and seems to act as a baffle for the air intake..
I concur :D
will not be any problems without it :wink:
Keep the Faith
nybongo
Post by nybongo » Mon Aug 01, 2011 8:02 pm
Thank you all for such quick responses. Its much appreciated. =D>
jaylee
Post by jaylee » Mon Aug 01, 2011 8:28 pm
missfixit70 wrote:The 2 holes attach to the heater air intake ducting via plastic scrivets, I usually poke the battery end between the battery & the clamp upright.
Like this...!
Post by missfixit70 » Mon Aug 01, 2011 8:47 pm
& if you need the scrivets, Simon Jones can supply them :wink:
nicstrike
Post by nicstrike » Mon Aug 01, 2011 10:02 pm
i think they are specially designed to flap & rattle around! at least thats all ours did 'till i wolloped a gert big cable tie around it and that was with the clips in place!!
jaylee
Post by jaylee » Mon Aug 01, 2011 10:39 pm
nicstrike wrote:i think they are specially designed to flap & rattle around! at least thats all ours did 'till i wolloped a gert big cable tie around it and that was with the clips in place!!
:lol: I packed the scrivet holes out using plaster raw plugs, the damn thing wont come off now...
