! confused!
Badger inkslinger
! confused!
Post by Badger inkslinger » Mon Aug 01, 2011 8:42 am
Hey guys, first post in a while again.
My heater glow plug keeps flashing.. its been into that garage, but they couldn't sort it, after saying they have been dealing with Mazdas for 5yrs + . so what i can find out it means there is a problem.. but what.. not asking you guys for the exact reason but if anyone else has had this problem maybe could spread a bit of light onto it?
thanks guys.. Badge
Last edited by Badger inkslinger on Mon Aug 01, 2011 9:15 am, edited 2 times in total.
Re: Interior Light flashing! confused!
Post by g8dhe » Mon Aug 01, 2011 9:05 am
Which light is doing the flashing the drivers area light, the main cabin light or the rear tailgate area light?
If its the drivers area light, what happens if you switch the spots on do they flash ?
Badger inkslinger
Post by Badger inkslinger » Mon Aug 01, 2011 9:09 am
Sorry apologies, just woken up and wasnt thinking straight haha and i need a word about the bloody interior light aswell.. and the windows! the list in endless.. haha its the heater glow plug light thats constantly flashing.. apparently its fault code 14 and something to do with the ECU unit thanks dude :) x
Re: ! confused!
Post by g8dhe » Mon Aug 01, 2011 9:22 am
R i g h t slight change of tack in that case!
Error 14 from the ECU is down as "BARO sensor (located within ECU)" see http://www.philmcfadden.co.uk/MazdaDiagnosticBox.htm
looking up that with Google suggests that the ECU's have a built in Barometric sensor in order to adjust the engine due to changes in height and air pressure, also this is internal to the ECU.
So if we believe the fault code then it sounds like you need a new ECU, but others on here may have ideas ?
Has the ECU been reset and does the error code re-appear each time ?
Manny
Re: ! confused!
Post by Manny » Mon Aug 01, 2011 9:36 am
Have you got a flat leisure battery (or has one been removed)? It could be a fuse ( No. 1 if I remember right) has blown. I have the interior lights etc. connected to th LB and when that went flat, and the fuse went with initial charge when split relay turned on, the glow plug lights would flash continously, and obviously the interior lights, mirrors, central locking would not work. All went back to normal when battery charged and fuse replaced.
Manny
A Bongo by any other name would still drive as sweet.
Re: ! confused!
Post by g8dhe » Mon Aug 01, 2011 10:05 am
Good point Manny !
Has any other work been done on the vehicle recently ? Might be worth checking that the plugs etc into the ECU are all OK, its located in the passenger footwell mounted on the firewall behind the glovebox. There maybe spare ECU's around either for checking that it really is the ECU at fault or even to replace it, not sure if all the ECU's are identical however ?
Re: ! confused!
Post by mikeonb4c » Tue Aug 02, 2011 12:23 pm
If you're in Stoke, wouldn't Ian Taylor (Bongo specialist, Stoke) be a good person to get to look at it (assuming you can't crack it yourself, with our help)
Badger inkslinger
Re: ! confused!
Post by Badger inkslinger » Sun Sep 11, 2011 3:56 pm
mikeonb4c wrote:If you're in Stoke, wouldn't Ian Taylor (Bongo specialist, Stoke) be a good person to get to look at it (assuming you can't crack it yourself, with our help)
thanks mike :) ill get on the case :D
Re: ! confused!
Post by bigdaddycain » Sun Sep 11, 2011 4:14 pm
I considered the leisure battery (if fitted) might be the fault too.... The only time i've ever had a flashing glowplug light was when the relay had popped. (worth getting checked out as that stops the rad fans and scavenger fan from working).
Simon Jones
Re: ! confused!
Post by Simon Jones » Sun Sep 11, 2011 11:20 pm
Two causes I've seen: fuse 1 or the temp sensor next to the handbrake being unplugged / open circuit.
jaylee
Re: ! confused!
Post by jaylee » Sun Sep 11, 2011 11:54 pm
Simon Jones wrote:Two causes I've seen: fuse 1 or the temp sensor next to the handbrake being unplugged / open circuit.
Good point Simon, but in my experience as well as flashing the glow light & running the scav fan, an unplugged scav sensor keeps the scav fan on when the engine is turned off too!
(Yep, i left mine unplugged once after a little work & thought i had a problem on a trip up to Gloucester!) :oops:
The scav fan don't switch on till after starting the engine then just stays on...? :?
What about checking the two wire key in ignition beep white connection block under the steering column? My glow light flashed with that unattached too! :roll:
