Had any rear arch work done yet?
Had any rear wheelarch work done yet?
Poll ended at Wed Aug 10, 2011 6:56 pm
Yes, they have been repaired in the past.
12
21%
No, they have never been repaired to the best of my knowledge.
20
34%
No, but they may require attention soon by the looks of them.
26
45%
Total votes: 58
David Edwards
Re: Had any rear arch work done yet?
Post by David Edwards » Tue Jul 12, 2011 7:07 pm
96 on a P plate and yep both need some attention, if I decide to keep it,lol.
blobber
Post by blobber » Tue Jul 12, 2011 10:22 pm
July 1995 tintop, been unprotected underneath untill recently, although it has a winter pack it lived in the south of japan.
Arches started to split at the seams, so had them done before it got any worse
Alan & Dot
Yes sir, I can Bongo !!
Post by g8dhe » Tue Jul 12, 2011 10:38 pm
Right a couple of pic's of our old rust;
Decided to get them seen to before they got to bad.
Post by bigdaddycain » Tue Jul 12, 2011 11:25 pm
So... Some good, some not so great. But at least most owners appear to be doing something about it. Here's the rub... Allow them to get rusty in the first place, or remedial work afterwards? I may be lucky insofar as i use another car during the dreaded salt laying months regardless of whether the bongo has been undersealed or not. (mine's re-oyled yearly).
There's plenty can be done to fend off the dreaded rust, and it may be easier than one thinks... Wash under those arches, remove accumulated crud, don't give moisture an oppotunity to accumulate and hold that moisture in. I class my bongo as a dry weather vehicle ( :roll: Yes, i've been known to not use it if it looks like rain :roll: ) But when i do get caught out, i hit any big puddles i can see... hard! Then jetwash the underneath (especially the arches) whilst still wet, and yes in some cases whilst it's still raining! That soft, sodden crud washes off really easily when it's good and soaked, and touchwood mine's still rustfree despite being in the UK for quite a few years now... [-o<
Velocette
Post by Velocette » Wed Jul 13, 2011 10:45 am
bigdaddycain wrote:So... Some good, some not so great. But at least most owners appear to be doing something about it. Here's the rub... Allow them to get rusty in the first place, or remedial work afterwards? I may be lucky insofar as i use another car during the dreaded salt laying months regardless of whether the bongo has been undersealed or not. (mine's re-oyled yearly).
Interesting thing I was told once by a colleague who had been doing a UK study for an OU degree was that body rot in cars tended to be less in regions with high rainfall than those with a drier climate. A possible reason being that the winter salt washes away quicker in the wetter regions.
M 80NGO
Location: Usually in My own wibbly wobbly lill world ! Otherwise Huntingdon.
Post by M 80NGO » Wed Jul 13, 2011 10:27 pm
blobber wrote:July 1995 tintop, been unprotected underneath untill recently, although it has a winter pack it lived in the south of japan.
Were they replaced or repaired ? if replaced what were they replaced with transit or merc ?
Getcarter
Post by Getcarter » Wed Jul 13, 2011 10:36 pm
Mines a new shape 2001 in white and I am starting to see the odd spot of rust but no bubbling yet. Should I do something now or wait?
V6 Tintop with LPG
blobber
Post by blobber » Wed Jul 13, 2011 11:08 pm
Hi M8ongo, they were done by Ian Taylor in Stoke, he fabricates his own smaller steel arches.
Dont know why, but i put July down at the start, it should be May......... #-o #-o #-o
Alan & Dot
A1tony
Post by A1tony » Thu Jul 14, 2011 10:20 am
Mine (a 99 Mk2 V6 AFT) has no rust at all anywhere. Even the labels underneath were still visible so I assume it has had a dry life in Japan. Rustmaster did their stuff on it last year with a full coating and a guarantee.
The one thing I have noticed is that the paint is much thinner than any other car I have ever owned. This maybe a contributory factor for some ???
Gripped
Post by Gripped » Thu Jul 14, 2011 12:45 pm
Mine started bubbling around the arches, so I just sanded them back to bare metal, primed and resprayed myself. Then black waxoyl underseal around the inside of the arch. Some minor bubbling came back in one or 2 places, but overall they are ok at the moment. Whenever I see rust, I just jump on it and sand/respray. It's like a continual job on the Bongo !!
If I had the money, I'd get a full body respray - in my investigations I discovered that it has been resprayed before, but then that is probably a good thing on a 15 year old vehicle !!
stuc
Post by stuc » Thu Jul 14, 2011 9:06 pm
"The one thing I have noticed is that the paint is much thinner than any other car I have ever owned. This maybe a contributory factor for some ???"
Just a note ref the above point, i measured the paint thickness on my front end before i painted it(original paint)and it had 40 microns on. Normal factory paint on most manufacturers is usually 80-110 so it is a bit thinner than normal. My bonnet now measures about 200 microns as it has high build primer water based basecoat and 1.5 coats of laquer. 1 micron=1000th of a mm.
Post by bigdaddycain » Thu Jul 14, 2011 10:51 pm
White bongo's seem to have the thinnest paint... Especially newer shaped examples. The guy at the local bodyshop is now VERY wary of machine mopping them, and uses a low tack masking tape as some old paint has been known to simply peel off with the masking tape! :shock:
jaylee
Post by jaylee » Thu Jul 14, 2011 11:12 pm
I dunno ste, i reckon the black ones do too...?!! For the age my arches are OK.. But i do have a little bubble/trouble about 2 to 3 inches back above the bumper line, passenger side! :roll: 8-[ 8-[
...& Stuc's could be the possible future of mine if i don't sort it! (Stuc's picture.)
:shock: :shock:
Post by bigdaddycain » Thu Jul 14, 2011 11:37 pm
I'd jump on it Jamie and hopefully nip it in the bud... Bud.
If you are ever up my way, i know a man who can. :wink:
jaylee
Post by jaylee » Fri Jul 15, 2011 12:04 am
bigdaddycain wrote:I'd jump on it Jamie and hopefully nip it in the bud... Bud.
Already a plan of action dude..
Drawn up ready for a walk round with a print out on a "clip-board" to sort bird doo acid marks/rust, shopping trolley scratches, :evil: fox damage to the bumper,
& the blister in question.....
Then the quote! :wink:
