SGL5 Diesel pump
SGL5 Diesel pump
Does anyone know the model number of the diesel pump as I have had a couple of bits drop out and I need to get a detailed schematic to see how they go back. I was replacing the shuttle valve seals on the bottom of the pump I think they are called the adjuster plunger and sleeve.
Re: SGL5 Diesel pump
zexel pump---yes ??
Yes it is mate
do a search under the author mikexgough(tab at the top right).look for posts regarding fuel pump, you should find a link to a good exploded diagram of the pump.
sorry i dont do links and stuff on puters im thick.
JAMIE !!!!!!!!.
JAMIE !!!!!!!!.
thanks geoff
. i hate computers
thats the one i was thinking of.
the only thing missing from the drawing is the shims that may be found at each end of the springs inside the lower plunger so take care of where these go /go back.
Last edited by Northern Bongolow on Sun Jul 10, 2011 11:28 pm, edited 1 time in total.
Cheers guys my have saved my bacon wife was threatening amputation if the bongo was not working by wednesday !
& grafting on arms like Mr Tickle...!?snakes46 wrote:Cheers guys my have saved my bacon wife was threatening amputation if the bongo was not working by wednesday !
WHAT!!!!?Northern Bongolow wrote:do a search under the author mikexgough(tab at the top right).look for posts regarding fuel pump, you should find a link to a good exploded diagram of the pump.
JAMIE !!!!!!!!.
Ady.. Try this?? viewtopic.clickthislinktillyourmousebreaks.com
your link dont work j.
and your supposed to be my puter guru
jaylee wrote:& grafting on arms like Mr Tickle...!?snakes46 wrote:Cheers guys my have saved my bacon wife was threatening amputation if the bongo was not working by wednesday !For the fuel pump job..!
(don't want any wrong ideas?!!)
JAMIE !!!!!!!!.![]()
Me mouse has just died.
Regards Ray & Christine
