Dodgy problem
Colin S
Dodgy problem
Post by Colin S » Sun Jul 10, 2011 9:01 pm
Hi got a very slight problem, had a new auto box fitted, now have intermittent fault, cant start in park sometimes have to shift to neutral to start other times starts in park no trouble. Any views please.
Colin S
Re: Dodgy problem
Post by Colin S » Sun Jul 10, 2011 9:21 pm
Cant start engine, but can when in neutral. :(
Kincaid
Re: Dodgy problem
Post by Kincaid » Sun Jul 10, 2011 9:23 pm
Colin S wrote:Cant start engine, but can when in neutral. :(
I was wondering if it could be the starter-motor solenoid points wearing out? They do kits for them on Ebay. But I can't really understand how this would improve on moving to Neutral.
Probably needs someone with knowledge of the autobox to help out on here......
Bongo Gymreig
Re: Dodgy problem
Post by Northern Bongolow » Sun Jul 10, 2011 10:33 pm
do a search on here for the gearbox interlock, its a cable lock that stops the gearbox lever moving whilst the footbrake isnt pressed,it locks everything up,check its adjusted/connected.
there have been times when it has broken under the gear lever.
Velocette
Re: Dodgy problem
Post by Velocette » Mon Jul 11, 2011 10:40 am
Northern Bongolow wrote:do a search on here for the gearbox interlock, its a cable lock that stops the gearbox lever moving whilst the footbrake isnt pressed,it locks everything up,check its adjusted/connected.
Mine's gone intermittent at times but it is OK at the moment. You used to have to select parrk a couple of times or wobble the shifter. I guess ADS noticed it and adjusted it when it was in there. :)
teenmal
Re: Dodgy problem
Post by teenmal » Mon Jul 11, 2011 11:52 am
Colin S wrote:Hi got a very slight problem,box fitte had a new auto d, now have intermittent fault, cant start in park sometimes have to shift to neutral to start other times starts in park no trouble. Any views please.
Hi,it might also be worthwhile having a look at the inhibitor on the side of the box..
19-444
http://lushprojects.com/bongopartsmk2/c ... 03.html#34
Cheers..
Alacrity
Re: Dodgy problem
Post by Alacrity » Mon Jul 11, 2011 1:25 pm
Teenmal is probably correct. Most range selector switches (used to be known as an inhibitor switch when all it did was inhibit starting in gear & operate reverse lights back pre 90's) are adjustable so it could just be that, but check your selector cable is correctly adjusted & the lever on the side of the transmission is going fully into the park position before adjusting the switch.
Colin S
Re: Dodgy problem
Post by Colin S » Thu Jul 14, 2011 9:35 pm
Thanks all, will get your points checked out.
Colin S
