Pre-Purchase check
Mike n Kay
Pre-Purchase check
Post by Mike n Kay » Fri Jul 08, 2011 10:44 am
Have my eye on a decent looking '98 Bongo but owner admits to not being mechanically minded so has it professionally serviced (have seen docs etc). Have a mechanic freind lined-up to check things over but we have time constraints so simple directions to access the engine (remove front seats & centre-console then engine cover) appreciated. Obvious things to look for apart from the dreaded wheel arch rust also welcome, it has been Waxoiled.
Mike n Kay
Triple/R
Re: Pre-Purchase check
Post by Triple/R » Fri Jul 08, 2011 12:01 pm
Mike n Kay wrote:Have my eye on a decent looking '98 Bongo but owner admits to not being mechanically minded so has it professionally serviced (have seen docs etc). Have a mechanic freind lined-up to check things over but we have time constraints so simple directions to access the engine (remove front seats & centre-console then engine cover) appreciated. Obvious things to look for apart from the dreaded wheel arch rust also welcome, it has been Waxoiled.
Mike n Kay
Welcome Mike & Kay :) don't take seats out~take centre console off (2 plastic wing nut type things)~lift carpet near handbrake & lift quite large black fastener up & also 2 fastener's (in footwell) under where floormat meets seat base~slide seat forward,drop seat backrest forward then lift seat (backwards) that apply's to both seats.
You obviously need to test drive it for a good few miles & get it up to temperature & make sure theres no smoke out of exhaust~make sure gears change smoothly~make sure everything works (electrically) check under bonnet to see if coolant header tank is discoloured & you can see level (but a lot are discoloured anyway) if it is pretty clear then that's a bonus.
Ask seller if he's had any coolant problem's (new cylinder head for example)~check the waxoiling he's had done cus a lot of people waxoil over the rust before selling.
The list goes on but if your taking a mechanic with you he should look for most of these things anyway.
Let us know how you get on :)
Regards Ray & Christine
Germarchip
Post by Germarchip » Fri Jul 08, 2011 12:22 pm
And remember, if your not sure another one is right round the corner :D
Post by Doone » Fri Jul 08, 2011 1:18 pm
There are a few pointers in the 'FAQ' ON THIS LINK
rita
Post by rita » Fri Jul 08, 2011 2:32 pm
Mike n Kay
Hi,this might help....
http://www.youtube.com/watch?v=XyeHJUCXNVs
Cheers..
Mike n Kay
Post by Mike n Kay » Sat Jul 09, 2011 5:59 am
Many thanks for replies rec'd so far youtube link especially, am I correct in assuming the procedure is mirrored to access the drivers-side. Not such an ardous task as I thought.
Apart from CV's are there any obvious gear-box snags readily identifiable, always been lucky with used motors apart from my first (Austin 110) & the box on that could drown out Concorde after 4months :cry:
Now where's my C/Card to join you guys officially
Mike n Kay
