Lurking behind fuel pump.?
jaylee
Post by jaylee » Thu Jun 23, 2011 12:22 pm
Anyone know what this is? I found it hanging loose behind the fuel pump on my pre travel checks, thought something was disconnected... So pulled it out & took some snaps!
The 2 wire loom run up to this block connector above the pump..
I have put it here out the way for time being...
Re: Lurking behind fuel pump.?
Post by missfixit70 » Thu Jun 23, 2011 12:24 pm
I think it's for the optional flux capacitor :-|
jaylee
Post by jaylee » Thu Jun 23, 2011 12:27 pm
missfixit70 wrote:I think it's for the optional flux capacitor :-|
I would have thought the loom would have been longer & run to just behind the cab at the back?? :lol:
It would also need about 1,210,000,000 watts of power... :mrgreen:
Post by missfixit70 » Thu Jun 23, 2011 12:44 pm
May explain Allifriendee's current drain? :wink:
jaylee
Post by jaylee » Thu Jun 23, 2011 12:55 pm
It can't be some bypass for the "fly by wire" set up, can it??
Mines a 95.. & just been trawling through Lushy P.
Diplomat
Post by Diplomat » Thu Jun 23, 2011 7:28 pm
I've no idea what it does but I can tell you where it's meant to be, rather than hanging loose!
Get a mirror and look in the area between the pump and a nearby vacuum device and you will find a slot fixed to the metalwork that the mistery device slides into (using the grooves just visible on its right hand flat side as viewed in the lower photo or the uderside as viewed in the top photo).
It falls out quite easily, possibly due to vibration. Refit it from the rear towards the front. Get it straight before pushing as forcing it could damage the fragile plastic.
My first thought was that it was some kind of knock sensor or similar and it needed to be in contact with something.
However it doesn't seem to affect the performance if it is hanging loose. Maybe it is just good practice to have it secured.
Love to know what it is for, though!
Frank
They flew, I took up naturism
jaylee
Post by jaylee » Thu Jun 23, 2011 9:24 pm
Nice one Frank! :D
After getting back home & reading your post, i found it...
It does slide in quite loose.. No damage to the plastic slots on the unit. (What ever it is.?) :roll:
What i did do, so it wont come adrift again... [-o< (I recently had a pump seal leak done!!!)
Removing the air filter hose for a little elbow room..
Is fit it in reverse, fitting the unit first... (Front to back.)
Then plugged in the loom... What a fiddle!
The theory is... It will only rattle in one direction, fully slotted in,using the loom running in the opposite direction...?!!
Glad i...
:D :D :D 8) =D> =D>
Diplomat
Post by Diplomat » Thu Jun 23, 2011 9:51 pm
Slots.
that's the word I was looking for.
All we need now is someone who knows what it is!
Frank
jaylee
Post by jaylee » Thu Jun 23, 2011 10:46 pm
It could have something to do with the vacuum solenoids..??
Geoff would know..! Been through the Lush pages & stumped if i know..?!!
Post by Northern Bongolow » Thu Jun 23, 2011 11:11 pm
[-X [-X [-X [-X [-X :wink:
Post by mikeonb4c » Fri Jun 24, 2011 12:22 am
Bob and I know a song that explains whats its all about:
http://www.youtube.com/watch?v=6yZD8r-ujiQ
:lol: :lol: :lol:
helen&tony
Post by helen&tony » Fri Jun 24, 2011 7:07 am
Hi Mike
Wrong song....here's what you're looking for:
http://www.youtube.com/watch?v=-tT_YO16lbU
corblimey
Post by corblimey » Fri Jun 24, 2011 7:41 am
I know what it is. Do I get a prize?
jaylee
Post by jaylee » Fri Jun 24, 2011 8:15 am
corblimey wrote:I know what it is. Do I get a prize?
Fergodsakes, just tell us!!?? :lol:
corblimey
Post by corblimey » Fri Jun 24, 2011 8:31 am
Unfortunately it's not a flux capacitor..... it's a T.P.S.C.R or Throttle Position Sensor Compensation Resistor for short.
